03.5's new wheels/ ?
03.5BlueMSP
2003.5 MSP
hey guys here they are. ?, what kind of flush am i??
That's sorta close to flush-ish. You using spacers? Looks like you need another 5mm.
What size tires? Edit: Nevermind, I see 225/40-18. Slightly large for a Protege. Probably why you're getting some rubbing. If you can track down where it is you might be able to fix it.
Most Protege owners with 18s use that size (215/35-18). You could probably get away with 215/40-18.
to me they are still to big looking for my style.
i put them up for sale, ill take signage photos when they are off and cleaned. its pooring here in iowa..
UPDATE! i found the rub, and it seems so simple to fix to me. let me know if my idea is possible and if its smart to do.
the rub is on the passanger inner plastic crap when fully turned to the left. there is a bump in the plastic for some reason, and the rub is only on that bump. i was thinking of taking out the plastic and cutting the area out and putting it back in.
thoughts?
That may work, as long as there isn't anything important on the other side that shouldn't get splashed on.
that looks flush to me
now is it the new age definition where wheels are 3 ft out of the fender and look like s***? no.
and for the plastic, youre fine. mine is rubbed away
