03.5 built MSP front rotating vibrations
BoostProtege
2003 Mazdaspeed Protege
So these vibrations have been getting really annoying, it's at just about any speed, worse at higher speeds and around corners, no noise just vibrations and a distinct rotating sound, I replaced all brake pads and rotors and one caliper, drilled and slotted rotors, ceramic pads, and new oem caliper(in the rear). I really don't want to **** up my Mfactory LSD, one cv axle was replaced about 3 years ago. The vibrations started right before I did the brakes, I finished them all and then got all new tires because I had been driving on basically racing slicks. The vibrations continued so I got it checked out by my mechanic and he said I need new axles and may as well do the wheel bearings as well but he also suggested greasing up the sliders on the calipers so I did that and greased the backs of the pads and put it all back together(should've seen the sliders before I did this, clumpy rusty grease looked like it had never been touched). After re-doing all of that Its better but I'm still getting the vibrations especially in turns
Any help is appreciated!
