Rear Hatch Issue
2019 GTR
This is really weird, but I am having a weird issue with my rear hatch tonight. It's raining very hard, so maybe that's why, but when I go to open it, I hear "2 clicks' and then it just "stops" it won't open. I can manually open it by pulling it (hope I'm not breaking anything more so - it's still under warranty). However, when I push the button to close it, it works, but again, will not open. WEIRD!
Anyway, I will call Mazda on Monday, but has anyone else encountered this? How often do you use your rear hatch? I barely even use mine. Ugh!
yrwei52
Contributor
Plano, Texas, USA
Could be bad connection in switches or power lifting motors are failing? Hope you can duplicate the problem when you get to the Mazda dealer.
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
I would guess the same thing. Maybe defective struts? I would not manually open it just in case something is caught in the mechanism that you can't see. If you can replicate the behaviour, take a video so you have something to show the dealer in case it happens to start working normally again.
Pitter
Pitter
Contributor
2020 CX-5 Signature Azul Metalico
Brings up something I was going to ask. Sometimes I'll open the hatch for someone who does't know the car to remove something and they then close it by hand before I can tell them to stop. Is manual closing bad for the hatch closing system?
Pitter
Pitter
Contributor
That's what I'm thinking but I'll have to ask at the dealer at my next service.
BMXDAD
2019 CX5 GT
Mazda 2015 CX9 GT
Got a CX5 GT. Today first time rear power hatch would not work. Can't get it open. Tried running thru the gears, pressing button, changing remote. Just dead.
sm1ke
Work In Progress..
Moderator
Contributor
Canada
'18 CX-9 Signature
Have you checked for blown fuses?
2019 CX5 Reserve AWD
How are you trying to open it? Button in car, FOB, rear switch?
I've found if you try to use the switch on the right of the steering wheel you have to have all doors
locked.
Top
