2017~2025 CX-5 Rear Differential Failure
not bad to do at 30k-its pricey but only takes a quart to do job...i used a jack/stands and it took an hour-parts guy asked why i need to buy 4 quarts-said i have owned honda/acura they always had me chasing my tail to get more fluid,and i may do it at 15k just cause i can
Darn Mazda diff and transfer case fluid is $30. Takes 1 quart to do both.
STILL $30 vs being down and the cost to replace. I'll change mine...
Just a note - new SG1 fluid isn't clear out of the bottle. It's like honey.. very close to this colour:
When I drained the fluid out of my CX-9 at 70k kms, it looked like brand new engine oil. Darker than the brand new fluid, but not bad by any means.
Thanks for clarifying the color!
For me, change in color indicates contamination. We can debate if this is enough to damage the gear boxes or send in a sample and have it analyzed and know.
I'll send a diff sample on our CX 5 at 30k and report back. We were in a time crunch to change the fluids on my friends 2nd Gen CX 5. So no sample collected.
I've seen contaminated fluid, diff, power steering and hydroboost wear out seals and the shafts. So bad that we changed out the P steering pump, hydraboost and diff pinion. Bearings were running ruff in the P steering pump. The shafts had grooves where the lip seals "seal".
When inspected, the differential or PTO oil is dark or black. During production, differential ring and pinion gears receive a manganese phosphate coating (commonly referred to as black oxide).
This coating forms a porous, oil-retentive surface that improves boundary lubrication and reduces adhesive wear during initial contact cycles. Designed as a sacrificial layer, it is gradually removed under load throughout the break-in process.
As a result, after the first few hundred miles, or at the initial gear oil service interval, the lubricant may appear darkened by the worn-off coating. It will contain trace ferrous particles from the normal run-in of the gear teeth and bearing surfaces
Excellent point. I didn't notice the fluid on the 2021 2500 series truck being dark. Maybe they didn't coat the gears with manganese phosphate.
On our drag race diffs, we don't coat the gears. Also, no break in procedure other than spinning the rear wheel on jack stands and listening and feeling for vibration.
Here is a thread from Bob is the Oil Guy. After reading this, I'll change the fluids at 20K, then on 30k intervals. $30.00 and an hours work may prevent costly repairs down the road. I'll put some of the fluids in a clear container and take pictures. Maybe send them off to be analyzed.
https://bobistheoilguy.com/forums/threads/phosphorous-coating-on-differentials.120944/
Manganese Phosphate Coatings | Calico Coatings
Yes. My post is specifically for the CX5.
Its nice that Mazda does that. I dont know wheter other car makers do it.
X2, AGAIN Mazda goes an extra step to produce the best product at a competitive price point.
It's a quirky car for sure, in a good kind of way! As an example the procedures for putting the rear brakes in maintenance mod and resetting the trans adaptive is interesting..WEEE
yes 35 is the msrp without local tax in US.
If you bought from your local dealer and the end user price was more than 35 (without tax) they are inflating the price retail.
When I purchase a brand new automobile, I always change the engine oil at the first 1000 mile mark. While doing that, I also had the dealership verify that my 2025 CX5 transfer case and rear differential were full of oil… which they were. The service guy informed me they would charge me extra ($39.99) to check those two gearbox levels. Seems like once upon a time checking all fluid levels was included with the oil change… he did have to remove the plastic cover to access the transfer case. I just wanted to verify the levels were good, after reading about folks having low levels from the factory.
I sure hope the guy REALLY checked your gear boxes! Rear is a snap to check. I've taken the front belly pan off so many times, it's a five minute job, max. I LIKE that belly pan, keeps the engine clean and helps aero.
Even though Mazda has made it difficult to service the gear boxes, requiring a 24mm box wrench, it's a very simple job. to drain and pump in new fluid.
I have been working on my friends 2021 CX 5 with him. I keep finding stuff that the techs messed up or overlooked. First was they didn't replace the oil plug/filter access panel. Next they replaced only one rear disk but not the other. The sensor in the oil pan was leaking oil, the screws were loose from when the engine was removed to fix and oil leak. Someone over tightened both front brake bleeder screws. I'm sure I've forgotten a few more.
Oddly, both of his gear boxes were at the correct level. We changed the fluids at 70k mi just the same.
I find stuff incorrectly installed or serviced. I check behind folks if I let them do some work for me.
I have been working on my friends 2021 CX 5 with him. I keep finding stuff that the techs messed up or overlooked. First was they didn't replace the oil plug/filter access panel. Next they replaced on rear disk but not the other. The sensor in the oil pan was leaking oil, the screws were loose from when the engine was removed to fix and oil leak. Someone over tightened both front brake bleeder screws. I'm sure I've forgotten a few more.
The dealership provides a short video of the underbelly inspection… it looked legit and he had the large plastic cover removed. I think the gaskets under the fill/drain plugs are supposed to be replaced when removed… now whether he did that, who knows. The guy working on my car sounded like (in the video) a grown man from the country, which was encouraging. Getting good mechanics to do this type of routine work must be challenging for the shops. I started working on cars as a teenager… today I imagine most of them don’t leave their video game consoles. Always good to double check work done by someone else.
Why would anyone want to stay with Mazda when rear differential is a common issue at under 100k miles, and the cost of replacement on average is $5500, never mind other accruing expenses? The response from corporate is beyond irresponsible.
Masda knows diffs are an issue . Mine 2021 was grenaded on test drive for another issue by the dealership at 66000. Dry as a bone claimed it was the tow company . Regardless It was Mazda's leaking diff seals that caused i in the first place Mazda is actively hiding this though if you see their in house service bulletins they refer to it. Mine was supposedly checked at 30,000. Ive had Mazdas fir years but this us the first to go beyond 60000 .Mazda wont cover it but us covering this issue up. Diffs simply shouldn't fail at this mileage. Do sone research and you'll see this isnt uncommon and if you own a cx5 check the diff out NOW before you runout of warranty per the abive. Im just amazed there hasn't been a recall however admitting theres a sleeping fault contingent on mileage kinda HURTS THE BRAND.
Hope the other suckers lilke myself and the above owner continue get the word out and burst the famzone bubble just as I was when Faced with a 6500$ repair ON ME.
FYIiii
Thanks Sid
FYIiii
Thanks Sid
Sorry to read your had this expensive repair.
This thread got me to put our CX5 diffs on the same maintenance as my 2500 truck. Check fluid level on 15k mi intervals and change it every 30k mi.
Ram has 30k mi differential service in their owners manual. Mazda??
My truck diff was still working at 200k mi, I changed out the entire unit because I could not get a seal to stop leaking. I bought a salvage yard entire unit for $500. We put in in 3 hours. Now, 290k mi on the truck, or 90 k on the used unit. I put a rear seal in it 70k miles later, it's not leaking a drop. It tows a 10,000 pound car hauler. Or sever duty.
Thanks to this thread, I checked our cx5 differentials and they were low on fluid from Mazda. This is my first all wheel drive with two differentials. The diffs are tiny compared to my truck and Dana 60 in my race car. Still they need the fluid level checked and changed, maybe more often than the brute force Domestics..
What I've learned, if I'm going to keep the car, I'm going to change ALL of the fluids on or before 30kmi. Mazda or what ever we drive.
Those days are gone where I never checked the levels or changed the fluids...fluids are cheap, parts and labor, NOT.
Brake fluid change is next, Its 26 months old. Past due..
Yea the rear diff has only 350ml but it takes aprox 500 to get to the brim of the fill hole.
Havent done the front yet but based on forum posts the level may be ok for it. Will change it soon and find out
This is the factory fill from my 2022 rear diff less than 30k miles.
As precise Mazda is in many areas, I wonder why many of us see lower than recommended diff fluid levels from the factory.
Lower fluid will improve fuel mileage and/or they know this level is ideal...
Unknown to me...never had a car with such discrepancy in the manual vs reality for quantities :)
Rear diff suggested 350ml vs fill to the top according to their instruction..gotta love the word aprox.
Front diff seems ok-ish. At least on mine.
May be fuel efficiency + some cost savings...who knows...
Nope. It's very simple - another consequence of the Green New Scam. Underfilling lubricants across thousands of vehicles adds up to less carbon-based materials and contributes to manufacturer carbon quotas. It also generates more revenue for Mazda with planned premature failure of the differential. Transmissions with 'lifetime fluid' accomplish the same thing. Religiously change your fluids every 30K miles and fill to proper levels, just like any other vehicle, and you'll be better off on the long run.
