2017~2025 Mazda App- what it can and can't do?
2021 CX-5 GT Premium
I just enrolled in the Mazda Connected Services, got the app set up and have some questions.
When I remote start, do I have any control over the HVAC settings from the app or is it only going to be set at whatever it was last set at?
It seems heated steering wheel or heated/vent seats are not remembered, remote start doesn't or can't turn these on?
Is there a tire pressure readout anywhere in the app?
Can I roll up my windows from the app (does locking the doors from app automatically roll up windows or anything like that)?
Is the liftgate controllable in the app? It will tell you status if it's opened or closed but no control seemingly?
Is the service interval shown in the app controlled by what is set within the infotainment settings menu or is it a separate tracker?
For the CX-5 platform, you can only control those in the car. And the car does not retain the heated seat settings, which default to off.
Correct.
Not for the CX-5.
No and no, window roll only via the 4-click remote procedure.
No, car only.
Unsure.
Wish I could answer these questions for you but I have not subscribed to Connected Services and don't plan to. I have the MyMazda app though, and while going through it I found that there is a tire pressure section. On the "Service" tab, scroll up to open the Health Report. Under the Health Check heading, there are line items for Tire Pressure and Tire Pressure Monitoring System. For me, these appear to just be indicators with check marks to show that the pressures are within spec, and that the TPMS sensors are working properly. They do not show individual tire pressures - not sure if this changes with a subscription.
I believe the Recommended Oil Change and Maintenance Milestones are based off of your settings in the car's Infotainment.
I don't think you're able to roll windows up remotely, either from the app or using the keyfob, due to safety concerns. You can roll them down with the keyfob.
I thought if you repeat the procedure, they go back up? I never use it but I'll test it later today.
I have the subscription and it does not show individual tire pressure.
I was wondering once how far away can you be and start the engine through the app? I tried once while I was flying, no luck.
Because you were disconnected from LTE.
We were flying relatively low level, the cellphone was showing signal so I figured I should give it a try. 10 minutes later, on the ground, the car was silent so I was thinking that maybe there is some sort of geolocation to see where the car is in relation to the cellphone and maybe, if you are too far, like not connected to the same cell tower, it won't let your app to connect to the car. Something like that. I should try again one of these days.
