Added 440cc injectors and the AFR goes from 13 when nearing boost to 10.5 at the full 6 psi. Build complete minus some fine tuning (for now).
If you don’t mind my asking, what. Tune are you running right now? I’ve been running the split second for a little while now and I keep getting into the 9’s on my afr. Still working on the tune.Added 440cc injectors and the AFR goes from 13 when nearing boost to 10.5 at the full 6 psi. Build complete minus some fine tuning (for now).
Surprisingly I set every box to 10 while pulling 1 degree per psi with the splitsecond kicking in at 0.5 psi and the automatic ecu maintains 10.5-11.5 under boostIf you don’t mind my asking, what. Tune are you running right now? I’ve been running the split second for a little while now and I keep getting into the 9’s on my afr. Still working on the tune.
Which Vortex FMU did you get, 12:01?Picked up a vortex’s FMU because the ecu was freaking tf out after 500 miles since the 440cc injectors cause it to max out the fuel trims.
I believe mine is 10:1 so I will be going back to stock injectorsWhich Vortex FMU did you get, 12:01?
