All us old guys are very experienced with oversteer. Learned to drive with the back end coming around from day one.
I am aware! I've heard some stories from my father, moving to western canada as a soviet refuge in the early 80's.
He told me his first vehicle was a buick skylark. Said the handling was sh*t and that it got 40L/100KM, but always mentioned that the engine was very powerful.
I'm still in my 20's, but I happened to learn how to drive on a RWD BMW. That thing was so fantastic in the snow.
Understeer sucks by comparison, can’t control a plow.
I was just surprised how bad the average driver is with handling a car. So bad, that "defaulting to understeer" is considered "safe."
The rare car that’s neutral is the best. My 2014 focus is such a car. Best handling I’ve ever owned, totally neutral, sticks till all 4 wheels break loose.
If you are very careful with your throttle and steering inputs, the front wheels will stick and the rear wheels break loose on the Mazda 6. With some basic suspension upgrades and an limited slip differential, maybe some small changes to negative camber, Mazda's chassis would be formidable on a track.
and then you can control it with brakes or power, or both together if you’re real good.
Haven't learned to do that yet!
Haven’t pushed my new cx-5, yet. But bet the stability control gets involved.
At least on the FWD 6, the traction control will not get involved until you are about halfway through the process of being fully sideways, counter steering. It is however very good at mitigating tire spin off the light by quickly shoving the transmission into second shortly after a first gear peel-out. AWD CX-5's I'm sure won't have that issue. Or even with just an LSD if you are FWD.
I find that the CX-5 was less engaging, less willing to approach its limit and more prone to understeering, but it is also like 600-700LB heavier than my car, which is huge. the AWD system and shorter wheelbase did seem to help with weight distribution somewhat, but i find that the rear wheels seldom get involved as far as putting down power goes while cornering.
Anyways, back to the topic of safety. Considering it is a heavy crossover, the CX-5 is competent and safe, just not very playful. From the Miata, to the 3/6, CX-5, probably even the CX-9 all have a similar sense of sporty flair built into their chassis and steering feel.
