You probably drive short distances and not often. Assuming no idle draw issue.I've got the issue of the battery being dead after a week or more.
What is the current best rated battery?
I need dependability in this vehicle. I'm ill and often need to go right then.
either measure amp draw or you could try to remove postive battery terminal wire and see if it sparks,think its better to grab a cheap meter that does dc amps and do it that wayI've got the issue of the battery being dead after a week or more.
I don't recommend this, could fry some expensive electronics. Best practice is to always remove the battery ground first.either measure amp draw or you could try to remove postive battery terminal wire and see if it sparks
Don't ever do this.you could try to remove postive battery terminal wire and see if it sparks,
Yea, I think so too. That was awful advice.think its better to grab a cheap meter that does dc amps and do it that way
Hey, I work part time in Sam’s Club tire and battery. Our battery is made by East Penn. It’s a Duracell branded battery. 3 year non prorated, replacement only warranty. 199 for the AGM. We use a saver that plugs into the obd2 port so no settings are lost. Most shops use them. Normally you loose the auto down on the windows and the fold in mirrors go back to the default of on. It might be a good thing to pull the negative cable for a few minutes, it might clear the previous battery management settings and start over for a fresh battery. Not sure if that will help though it won’t hurt. Only Cx5 s with istop have a scan tool reset feature for the battery management system.
