New MAZDA CONNECT Gracenote update 17 November 2025
I tried updating this today and got an "Unable to update" error. Then I noticed I already had this same version installed in January of 2024:
So my car thinks this update file is 1.1.1.03126 and won't proceed with the update.
Despite the file being named Gracenote_1.1.1.03399_NA.
Something is clearly not right. I would double-check it.
Is the new update file the only Gracenote update file on your USB stick, and is it located in the root directory?
Maybe the file is incomplete or corrupted in some way?
Download it again and put it on another USB stick.
I also have two entries in the Gracenote (EU version) history from January 2024.
As you can see in my picture, that has nothing to do with the new November 2025 update.
I only showed the picture to show when I had last updated and to what version, and to confirm it did not complete.
I just downloaded the file again and when I tried to update, I get this, same as yesterday:
Again, showing the wrong version number.
But this time, it completed successfully. Last time, it said it was unable to update. It's possible that file was corrupted somehow.
Here it is with the correct version number now:
Strange.
For the older MZDConnect you can use this page.
I tried digging a bit deeper into this.
The newer gracenote.mcg contains a .bin file, unfortunately, not the type of mountable .bin I was hoping for. Binwalk picks it up as thousands of JPEG images inside, all very small file size so pretty sure this isn't correct.
The older .up style format is basically a zip file with a nice structure inside. I was hoping to use the data from the newer one and create an new .up file for the older cars :(
