Dealer won't use synthetic oil - 2022 CX-5 Turbo
Maintaining your Mazda with the best synthetic oil is essential for ensuring optimal performance, fuel efficiency, and engine longevity. By choosing high-quality synthetic oil brands like Mobil 1 Extended Performance, Castrol EDGE Full Synthetic, or Royal Purple High-Performance Synthetic, you can provide your Mazda with the protection it needs to run smoothly and efficiently.
Ready to give your Mazda the care it deserves? Start by selecting the best synthetic oil for your vehicle and experience the difference it can make. And if you need further assistance, don't hesitate to book a consultation with a mechanic at Mazda of New Bern!
Most car dealerships are privately owned entities, not owned by the car manufacturers themselves. That means that they (dealerships) can do whatever they want, as long as it doesn't breach whatever agreement they have with the manufacturer, and as long as it doesn't hurt or misrepresent the brand. So, the dealership can recommend a better oil, in order to offer a "premium" oil change that they can charge a bit more for. However, Mazda, as a brand, still does not require full synthetic oil for the 2.5T engine, and Mazda as a brand, has not released any TSBs or special service campaigns to advise owners to use full synthetic.
IMO, everyone should be using full synthetic if it's available to them. The cost difference between conventional and full synthetic is negligible, but the benefits are clear. Regardless of Mazda choosing not to recommend full synthetic for the 2.5T, I'll still use it for every oil change.
You are correct. I emailed my contact in Irvine Ca Mazda America. Mazda does not take a position on synthetic or non synthetic. They only specify SAE and API certified oil. I also use only full synthetic.
Just want to add that my very old Mazda uses conventional oil 20w50 or 10w40. Castrol GTX is most popular. I have also ordered Amazon Basics 20w50 in the past. For my application, I add Lucas oil stabilizer to make it even thicker. Have you seen oil that comes out of the bottle like honey? 🤣
The Castrol website shows 5w20 and 5w30 in their GTX conventional oil lineup.
These small displacement 4 cyl turbo engines, putting out over 200 HP, need fresh oil more often than you think. The tolerances are much tighter to begin with, so any kind of contaminants or sludge can destroy them. Then there's the turbo of course, which needs good clean oil. Lastly is the matter of the direct injection technology that's used now. It is a known problem that these engines all suffer from oil dilution to some degree.
My 330 hp supercharged, turbo charged engine does not suffer oil dilution to any noticeable degree.
So far I've been kind of amazed at my dealer's behavior with regard to oil changes. I have the NA engine in my '23 CX-5 and when it came time for the first (free) service they agreed to use Mazda hi-moly synthetic oil, which I have always used in all my Mazdas with SkyActiv engines (3 to date). I told them to put the empties in the boot to verify they had complied, which they did. A couple of weeks ago the same dealer's service department called with an $99 service offer, which the car is just about in need of. I asked if that included the hi-moly oil and she said that their records showed that they had used it for the first service, so they would continue that at the promo price. She even stated that, in writing, in a confirming email. Considering I pay $87 from an online vendor for 5 qts of this oil and a Mazda filter for my Mazda 3 (which I service myself), I figured that was a pretty sweet deal!
One of the 4 or 5 times I visited the Mazda dealer with my 2018 CX-5, I can't remember what the visit was for but not an oil service, they told me that the oil level was too high and they removed some.
Days later I got an oil light on my dash. I checked the oil level and it was low. I filled it the correct level and never had another issue. They probably measured the level immediately after shutting off the engine or somethign.
Moral of the story is, I don't trust the dealer to do the oil change properly. Its much less expensive, takes less time, and is more convenient for me to change it myself. Plus I can use better materials and know the condition it was left in and if there was anything unusual to take note of.
I have three cars. I use 5W30 in all three. Full synthetic. Synthetic is not much more expensive than conventional. Worth the extra price.
I stopped changing my own oil because it's more convenient to have my Indy do it. I drive somewhere. I wait an hour. I work while I wait. Done.
Instead of buying parts, crawling around on the cement, dealing with hot oil , and hope you don't spill any on the driveway!!!
... and then my favorite part: disposing of said oil.
So while I agree with you on principle...I don't agree it's specifically more convenient.
LOL
My problem is I don't trust the dealers and repair shops to put in my preferred 5W30 oil. They will tell you what ever you want to hear and then put whatever they have on hand.
LOL
I do it in the garage where I normally park. I have a Fumoto valve and I don't use ramps or jack. The oil goes in a polypropylene milk jug and is set out with the recycling. Oil and filter together is about $30 bought when the price is good and stored in the garage. I put wing heads on the 2 screws to make them thumb screws so the only tool needed in the process is a flathead or pliers to pull the 2 pin clips for the cover. I can loosen the oil filter with my nitrile-gloved hand, but if not I have strap wrenches in the garage.
I only change the oil about once per year, so the hardest part is remembering to have everything in place and the sequence so I only have to crawl under once, or twice if I want to check for leaks before replacing the access cover.
Dealer requires an advance appointment during business ours. Wait to check in, wait to get started, 20+ minute drive each direction, list of dubious "needs" at ridiculous prices, etc.
I don't have a trusted Indy shop or mechanic. That would be nice. At least I could send family members to them and such.
If you keep oil for long periods, make sure to shake it up from time to time as the additives settle to the bottom. Once they form a sludge it's hard to get it mixed again.
For the screws on the cover, what size of wing heads to use? I have three on my cover. They are the reason why I always use ramps because I am so used to pointing a screwdriver straight up. On my other lower cars with no covers, I just need to reach under to flip the switch on the valve.
Edit: Same size as the ones on there. 🙂 I was thinking adding a pair of wings to the existing screws but you meant replacing them with winged-screws.
I've always run 10-30 in my newer cars.
Is there any harm in doing so with my 2022 non turbo mazda?
If you’re running a thicker oil for better protection, I’d personally consider 0w-30 for the best of both worlds. I’m doing this on my Titan as im just not thrilled with the idea of towing nearly 5,000 pounds over hills, during southern summers, with 0w-20.
Folks complain about 0w-20 being for gas mileage and environmental reasons at the expense of increased wear. I get it, won’t argue it. However, our newer vehicles like the CX-5 rev up and hold at 1500 rpm’s at startup to better reduce emissions. Lower viscosity oil is going to flow better when cold and get where it needs to be faster vs a thicker viscosity.
5w? Not a huge difference vs 0w imo, especially considering 5w-30 is spec’d outside the US. 10w-30? That’s another step higher on viscosity vs the manufacturer 0w US specification. Stick with 0w and bump the 20 to 30 and you have an oil with cold and hot viscosities that the engine design would already experience with 0w-20 alone. Lots of informative YouTube videos out there for better understanding.
Highly encourage a watch of this video especially around the 8:50 mark onward to support my thinking.
And to stay on topic with this thread, 0w is achieved through synthetic or synthetic blend vs conventional oil :D
Actually, I looked for replacement screws but wound up 3D printing some press fit on wings to the existing screws. If I did again I'd use lowercase and a different font for the emboss :). They've worked without issue for almost 5 years.
Wow you can make your own! So this is more like a tool/wrench?
I have one compact L shaped tool to hold screw bits (for the MINI). Will try this weekend to see if I can remove the access cover without a ramp. 😅
No, not a tool. I made one for each screw and pressed it on. It's an interference fit with crush ribs, so its on there good. If you look closely in the 2nd picture you can see the ribs. You can see that the part is slit down the middle so it will spread open a little when its pushed on. So the part will flex open and it will squeeze the screw head.
I'd considered using glue. These were a test, but they held so well I decided I was done.
You still have the file and can print more? 🤩
