2017~2025 CX-5 Original Front Brakes, Outside Pads No Wear, Inside Finished?
Davidiot
Ballistic Reentry Vehicle
2020 CX-5 GT PP
I first noticed a cyclic rubbing/dragging sound seemingly coming from one or the other of my front wheels while driving with the radio off one day. The rub seemed to be consistent with each revolution of a wheel (the frequency of the rubbing sound quickly increasing with the vehicle’s speed). This was soon followed by some aggressive steering-wheel shaking during braking, making the culprit much more certain. Only 24,000 miles since I bought my CX-5 brand-new, I wasn’t expecting to need brakes yet, much less new rotors 😭.
Since the first 6,000 miles, though, my car’s really only seen town miles, almost exclusively stop & go, so I had to consider that perhaps this mileage could be normal, given my circumstances? Not sure how I managed to warp (at least one of the) rotors without ever hearing any warning sounds from brake wear indicators; but might that be because Mazda doesn’t install them?
I went ahead and bought new front rotors and a set of brake pads for all 4 wheels, and borrowed a pair of jack stands and a couple of torque wrenches so I could get started on doing the work myself. Having only two jack stands and the scissor jack from my trunk, I haven’t been able to take a look at the rear brakes yet; but I did pull off the fronts earlier today.
I am in SHOCK at what I found. Wtf, Mazda?
The inside pads on both the front left and front right wheels are worn down completely; while the outside pads are still almost as fat as the brand new replacements I just bought. How could this have happened with factory-installed brakes? What other parts am I now looking at having to replace to make sure the same thing doesn’t happen again to my new rotors and pads?
... I am in SHOCK at what I found. Wtf, Mazda? ...
I don't have time to type much at the moment, but to be honest, this isn't a "WTF Mazda" problem rather it's a lack of brake maintenance in a highly corrosive environment. If you do your own maintenance, I can tell you what to do in the future to prevent that from happening. If you're paying someone to do your maintenance, however, you should find a new shop! (Unless you turned down suggested brake maintenance)
Upvote 0
Wow that sure is a lot of corrosion for a 5yr old car, you must be driving roads that are salted in the winter. The uneven wear is likely due to lack of lubrication on the caliper pins, at this point they may be corroded too. Depending on the extent of the corrosion you will need new calipers or best case, a thorough cleaning and lubrication of the pins.
Upvote 0
Wow, this is certainly the worst case of uneven pad wear I've seen. I had a 2018 CX-9 with a small amount of uneven pad wear on one side, and indeed, it was due to a lack of remaining lube on the slide pin on that side, which resulted in some corrosion starting to form on the pin itself.
In your case, if the pins have corroded, I would replace them or at least grind the corrosion off, then make sure they are lubricated before you reinstall them. Also double check the slide pin rubber boots to make sure they aren't damaged - replace them if they are. Hopefully that resolves the issue.
Upvote 0
That is really bad.
Not sure if it's relevant, but my 2023 had one of the rear pad retaining clips installed incorrectly. Wouldn't have noticed if I didn't do my pad swap.
Upvote 0
Did you measure any runout or out of round on the rotors? They look rusty. I bet replacing parts is a good idea considering the obvious rust. Plus the sticky calipers and guide pins. I lubed mine because of sticking a few years back and I haven't noticed any problems.
I found if I loosened both bolts that hold the caliper but only remove one of them I can rotate the caliper enough to remove the pins and clean them.
Be sure and follow the directions carefully to disable the Electric Parking Brake before servicing (don't wait til you have it apart_)> They are a big problem, and according to what I've read here the rear brakes usually have more wear than the fronts.
Your 2020 only has 25000 miles, but the years take their toll. Brake fluid gets contaminated, too. so consider if it's been changed recently.
Upvote 0
+1 on the brake fluid flush/change as recommended above. Let me add a few more random comments:
With the apparently corrosive environment and amount of rust, be sure to clean/scrape/file all contact points where caliper and pads meet. There are caliper files made for this purpose ( or just a coarse one works along with a scraper like an old wood chisel and a wire brush). And after cleaning apply caliper grease to the area underneath the stainless steel pad guides to prevent "rust jacking" where rust expands and forces the pad guide tightly against the pad ears and binds up pad movement within the caliper slot.
Be sure to use an approved caliper grease that is rubber friendly. One of the pins has a small rubber ring near the tip and wrong grease could swell it causing a bind in it's bore.
The pins can be reused if not worn even if just discolored. New pins (2) are only ~$10 at Autozone. Might want to replace the little rubber accordion boots if dried out from road chemicals/environment. Only ~$5 for 2 and should include new small rubber ring but be careful because I've come across where that little ring is too thick and makes for tight fit so I just reused the original ring, so don't cut or tear it if removing, you may need to reuse it.
Once lubed the pins have a tendency to not stay in but pop back out because trapped air acts like a spring so it needs to be "burped" by lifting the edge of the rubber accordion boot and pushing the pin in to force the trapped air out. Otherwise that trapped air acting like a spring can force the caliper(and pads) against the rotor.
Thinking back years ago when doing the rear for the first time I remember remarking at the small amount of grease on the pins when removed. Felt like Mazda could have added a little more.
Be careful when tightening the small bolts that retain the pins. I twisted one off in the pin and had to buy new pins (they should come with bolts) in lieu of trying to extract the bolt shank that broke off flush with the pin. It has a low torque spec, around 23 ft-lb IIRC.
I don't know if you know/follow all of this already in which case it may just be a reminder if you haven't done brakes in a while.
P.S. If you elect to not change brake fluid maybe at least open the bleeder when compressing the piston to force old dirty fluid out instead of forcing it back up the line. It also helps to be loosened because in another 5 years it may be corroded in place from never being loosened and twist off when trying to open. Good luck.
Upvote 0
[Edited significantly since first post.]
Sorry for the late reply: my internet access is limited, and I was delayed in being able to restart this project.
Re: Need for regular maintenance: my cash is sadly even more limited. My situation was very different when I bought the car.
Admittedly, the brakes never got looked at unless the dealer did it during my first two oil changes back when I still had the means to dedicate trips to such endeavors; at approximately 5,500 miles and 12,000 miles. They definitely haven’t been looked at since then.
I did change the oil and filter myself at about 19,500 miles (but it had been at least two years since the previous change with only local driving).
I never expected to get sick, go broke, and eventually need to spend nine months living in it (before the VA was able to help get me into a new place). It’s been absolutely everything I could do just to keep it — and I owe Mazda Financial HUGE for that [since 2023, they have five times (!!) moved two-months worth of payments to the back end of my loan in order to prevent my account being sent to repossession — never charging a fee, nor switching my loan from my original 60 month zero-interest deal to one with interest (even though it’s now been extended to a 70 month deal) — absolute life savers, the fine people at Mazda Financial. I’d never have imagined ANY company ever bending over backward to do such enormous kindnesses for someone in this day and age, even once — much less five different times].
My first year with the car was great — the next four and a half … much less so (but not due to the car! — I still love the car).
I just meant that since I bought the car new, and used it regularly the first two years … shouldn’t there have been at least SOME wear on the inside pads? The fact that both outside pads look nearly new, while both inside pads have nothing left but the metal backing plate … this doesn’t make sense to me.
Yes, I’d like to know how to prevent that; but I’d also like to know how they got that way in the first place. Thanks.
Upvote 0
You know in the manual when it says to lubricate your caliper pins? This is why it says that.
The guide pins? Four to each wheel?
FWIW, that doesn’t show up anywhere I can see (at least in the online version of the manual on Mazda’s website; if it’s in my printed manual, I must have missed it there as well). How often does it presumably say that needs to be done?
I don’t mind being criticized, but it’d be more helpful to both myself and anyone else who might be reading to actually provide the information asked for — or unasked for if you feel it’s relevant. Like, maybe explain (or link to sources which explain) what the caliper pins are, how to clean and lubricate them, and how often that should be done.
Just a suggestion. 🤷🏻‍♂️
Upvote 0
A five-year old car with fewer than 24,000 miles 😔. The pins are fine, nice and shiny once degreased and wiped clean. I broke a bolt off in one while dumbly attempting to loosen it in the wrong direction, so grabbed a new set rather than try to drill the bolt shaft out. The old ones look pretty much the same as the new. Calipers seem to be cleaning up nicely since I was able to acquire a set of rotary wire brushes to make the job easier.
NW New Jersey; so yes, the roads are salted in winter. Car has never been fortunate enough to be garaged, sadly.
Upvote 0
Thanks for this advice.
I hadn’t been able to finish this job since I posted here; couldn’t get the old rotors off and it was too late in the evening to go about making a bunch of noise trying to hammer them … and the gentleman who loaned me his jack-stands needed them back … so I had to put the wheels back on with the old brake pads until I could get back to it … which I’m doing today. I didn’t remove the slide pin boots the first time (didn’t want to risk tearing them if they weren’t meant to be removed) but I’ll be doing that today since I see I can pick up a complete new set for just $24 or so ($12 per wheel).
Upvote 0
Thanks! I’ll try to compare the pics I took at each step before removing things with some photos that show the correct orientation. 👍🏼
Upvote 0
Thanks for all this! Because of all the shaking I assumed the rotors were toast and bought new ones (for the fronts). Going to give replacing them another try today. Haven’t looked at the back rotors (or pads yet), though I did buy a new set of rear pads as well, since it only cost a couple extra dollars (they put me over the threshold to qualify for a $50 gift card via rebate).
Given all the uneven wear on the front, I’m hoping the backs will be in better shape and I won’t need new rear rotors yet — because I definitely can’t afford them. 😞🤞🏼🙏🏻
Edited to Add:
Oh! Also thanks for the reminder about turning off the EPB before touching the rears, and rotating the caliper assembly up on the top pin without removing it, to more easily maintain the slide pins and lubricant the pad clips. 👍🏼
I’d seen those tips online, but it never hurts to repeat them since others might not have!
Upvote 0
1:
2:
Your entire post was excellent information — Thank you!
Re: 1 — guy at the parts store told me they should pop back out if lubed correctly — is that wrong? Should they instead automatically retract if pulled out and released?
Re: 2 — I did that! Got my lefty-loosy, righty-tighty backwards when attempting to loosen the bolt from the opposite side (initially got more resistance than expected; mistakenly thought I’d got it backwards, and then cranked too hard the other way). Doh!
Upvote 0
That would be the Sil-Glyde packets I picked up from the auto parts store.
I picked up a couple of those .14 oz packs too; and then added a 1oz tube of synthetic ‘Prestone Brake Parts Lubricant’ when I realized I might need more lube then I was initially expecting, given the condition of the parts I removed.
Thank you!
Upvote 0
... Because of all the shaking I assumed the rotors were toast and bought new ones (for the fronts). Going to give replacing them another try today. ...
There's a small M8-1.25 threaded bolt hole (8mm diameter with 1.25mm thread pitch) on the rotor "hat" that you run a bolt into to help "pop" the rotor off. I believe it's the same size/thread pitch as the spare tire hold down bolt IIRC 🤔
Now, with your particular level of corrosion, you're going to have to be careful threading a bolt in there (oil the bolt up good) and slowly and carefully continue to add turns on the bolt while whacking the rotor with a hammer. Between the pressure of the bolt pushing the rotor off and vibrations from the hammer, it should eventually pop off.
I always put never-seize compound between the rotor and the hub and every time I rotate the tires I work the calipers back and forth on their slide pins and wiggle the rotor from the hub so they're never stuck 👍
[edited for bolt size ... Thanks Jmaz]
Upvote 0
