Is that an actual plastic replacement or some adhesive-backed decal?Did the ghost touch repair. (disconnected the ribbon) and put new panels over the scratched piano black on the center console and door cards. View attachment 344652
Can you list what those seals are?I spent time to coat all my rubber seals with silicone spray
They are a plastic covers. You just stick them over the scratched panels. If something happens and you need to open up the area for maintenance or a repair you will have to pop them up. No big deal they are cheap.Is that an actual plastic replacement or some adhesive-backed decal?
The Turbo uses the filter 1WPY-14-302.Today I did my first oil and filter change on our new 2025 Signature at 830 miles, and prepared a sample to send off to Blackstone for analysis. I used the Mazda 1WPE-14-302 filter and Mobil 1 ESP 5W30 and will do 5,000 mile changes from now on.
Thanks, I corrected my post as I got the 2.5 turbo filter confused with my 2.0 MX-5... one letter difference and they even look the same.The Turbo uses the filter 1WPY-14-302.
The only difference appears to be the pressure required to activate the bypass, but it must be so for a reason.
