Latest little maintenance step: Battery terminal cleaning.
Got rid of the minor corrosion, neutralized the acids, put on a pair of anti-corrision felt discs. Used a spray-on protectant on the terminals and cable ends, once the cables were reconnected.
'16 2.5L NA, 80,400m. Changed spark plugs (NGK); Cleaned throttle body. Not completely satisfied as there was carbon buildup that was caked on the back. Did the best I could with cleaner and rags. Probably could have done a better job with a toothbrush, but didn't have one handy.
Did the ghost touch repair. (disconnected the ribbon) and put new panels over the scratched piano black on the center console and door cards.
I bought my cx-5 2021 GT this week and it came fully detailed but I spent time to coat all my rubber seals with silicone spray.....
.....and then I stood back, took a look and smiled a long while! Great car so far and missed owning a Japanese made car!
Is that an actual plastic replacement or some adhesive-backed decal?
They are a plastic covers. You just stick them over the scratched panels. If something happens and you need to open up the area for maintenance or a repair you will have to pop them up. No big deal they are cheap.
