TLDR: Lift gate, infotainment screen, head up display, key less entry, keys, heated seats, heated steering wheel, interior lights, USB’s, and trip monitor stopped working suddenly. Car runs fine. Battery checked multiple times and showed to be “good”, and no fuses appear to be blown.
I have a 2018 Mazda CX-5 Grand Touring AWD. About two weeks ago the lift gate started to intermediately not want to open and give 3 beeps. It would not open with the key, rear button, or driver side button. Disconnecting and reconnecting the battery would temporarily fix the issue or over time it would decide to work on its own, but it kept returning.
A week after this started, I got a check engine light and took the car to O'Reilly to get the codes checked and to get the battery checked. The codes were U0100, U0115, U0121, and the battery and alternator showed good on the tests with the battery installed in the car. The check engine light would go away and come back randomly it seemed.
Several days later it all got worse. The lift gate issues persist but now the infotainment screen (tried back+nav+mute but nothing happened), head up display, key less entry, keys (not responding to both keys and have to place them next to start button to start the car), heated seats, heated steering wheel, interior lights, and USB’s in the console don’t work. Also the trip monitor resets after each drive. I took the battery out of the car and got it tested again at O’Reilly and the battery tested good again, it is an Optimum RedTop that is 2.75 years old. I tried checking all the fuses in the engine compartment and under the steering wheel and didn’t see any that looked bad.
The car seems to run fine otherwise. I just have to unlock/lock the car with the physical key.
Does anyone have any idea what could be causing all of these issues?
