Mazda Dealership - Warranty Recall Work Results in a Brake Fluid Leak
Lazy2.5
2015 Mazda 6 - AT - Tuned
Ontario
I brought my 2015 Mazda 6 to a local Mazda Dealership for Safety Recall 1217F - corrosion within the parking brake mechanism causing the rear brake calipers to seize, and reducing parking brake engagement efficacy. The overall experience was not just disappointing - it created a serious safety hazard.
Upon dropping off the car, I expressed my concern about an active brake rub. The service desk and mechanic disregarded this, claiming the vehicle was 'fine to drive' with what turned out to be severely seized rear calipers. They also claimed my calipers were not original, a questionable assertion for a vehicle that has been in my family since it was purchased brand-new in December 2014. I am well aware the defective calipers were original. This claim appears to have been an excuse to justify their decision to save costs by reusing the original, heavily corroded caliper brackets instead of replacing the entire unit. (Pictures attached) While this may technically satisfy the recall, it is not a complete or lasting solution.
The most concerning issue is a direct result of their work: a brake fluid leak from reusing existing crush washers, as pictured. This serious safety hazard, along with a soft brake pedal that moves through nearly half of it's total travel before actually engaging the brakes (improper fluid bleed,) has rendered my car unsafe to drive.
While the recall was addressed (At a bare minimum,) their disregard for my initial safety concerns and the negligent work that created a new, dangerous brake fluid leak is completely unacceptable.
call mazda customer service and voice your concerns... you went to a BAD dealership who decided that it wasn't worth their time to replace the calipers because warranty pays horrible labor rates (recalls are charged by the dealership via warranty claim)
most warranty claims are at the discretion of the dealer, not corporate, unless it's some serious high dollar deal... used to be, it required a district service manager to come see and sign off on, but not anymore.... the process is now remote and more automated, so there's zero excuse for this
a good dealership wouldn't have stuck it to you
This dealer was actually well regarded as far as reviews go.
I've showed these pictures to the service manager, who promptly had the vehicle towed back to the dealer for an "investigation" and rectification of the issue, at their expense.
The calipers were replaced, at least there is that.
Update:
The service manager replaced both caliper brackets. Looking underneath the car again, both banjo bolts are now dry. They even removed the rear rotors to clean the hubs to ensure the rotor sits flush, and sanded down the pads.
Brakes feel a lot better.
they should've replaced the pads, not "sanded down the pads"... that's not the official procedure from mazda... if the grooves or rust pitting in the rotors are excessive, the rotors MIGHT get turned but at a 1mm tolerance level compared to new, and the pads gets replaced
The pads were only one year old with 8mm remaining. If they wanted to replace it on their own dime, i'm not complaining. But, to have the existing ones sanded down for free, that's fine by me.
it's not about wear, it's about the state of the materials/evenness of it
if the recall or TSB instructions say to replace the pads after certain criteria, you just do it, no matter if the pads are "like new"
I've replaced "perfectly good" brake pads before under warranty because of some sort of defective concern... that's what the TSB said to do, and there was no warranty chargeback from mazda
