doesn't say that in my 2023 OM...The local dealership told my buddy that his warranty could be voided if he didn't get it done...he does his own oil changes and he took it in to have his air condition checked because he said it is not blowing cold air...they did find a leak and said they needed to order parts and told him he needed his tranny fluid and rear diff oil changed to the tune of $800 he told them he needed to research and they told him he was risking his drivetrain warranty by not doing it..he is around 30000 miles. I told him to have them show him in the owners manual where it says thatIn the owners manual for my 2016.5 CX-5, in the Maintenance Schedule section, it mentions the transfer oil and the rear differential oil.
Change frequency isn't shown in the table itself, but the notes indicate the following -- both for Schedule 1 as well as the Schedule 2 severe driving conditions sections:
*5 If the vehicle is operated primarily under any of the following conditions, replace the rear differential oil at every 48,000 km (30,000 miles).a) Towing a trailer or using a car-top carrierb) Driving in dusty, sandy or wet conditionsc) Extended periods of idling or low speed operationd) Repeated short trips of less than 16 km (10 miles)*6 If this component has been submerged in water, the oil should be replaced.
Of course, that means if none of those conditions exist then Mazda's suggesting that there is no recommended interval for changing the trans/diff fluids.
Many do these every 30Kmi. I acquired my own vehicle pre-owned at just under 80Kmi. Did the fluids then, at ~35Kmi more I did them again. At 150-160Kmi, it'll be time for the next swap. IMO, better to treat it conservatively than to let it go as a so-called "lifetime" fluid. Particularly with the trans, since there's a filter in there as well.
My dealer did a drain/fill for $120.When I asked my dealer about a transmission fluid change, they told me the interval was over 100k. I got a price anyway, which was insanely high (600 or so), and went elsewhere as they didn't seem to want to do it. The indie shop was about 250. I had mine done at 30k. What my dealer said invalidates what your dealer told you. If it were a warranty issue, it would be in the manual. I need to have my rear diff fluid changed as well.
it's tricky doing this... without a proper scan tool to check the fluid temps, you can screw up the amount you put in... it needs to be checked at around 50 degrees celsius (122 degrees fahrenheit) or you'll get it wrongWhen I asked my dealer about a transmission fluid change, they told me the interval was over 100k. I got a price anyway, which was insanely high (600 or so), and went elsewhere as they didn't seem to want to do it. The indie shop was about 250. I had mine done at 30k. What my dealer said invalidates what your dealer told you. If it were a warranty issue, it would be in the manual. I need to have my rear diff fluid changed as well.
I changed our 3's at 50k, using full synthetic ravenol ATF-FZ (the only aftermarket ATF-FZ available) because the mazda ones aren't synthetic... paid my dealer to do it so that they could use their flushing machine to change it all out with 3 gallons of that synthetic fluid, which costed a fortune... buddy hookup of 1 hour legit labor cost plus the $35 rip off of their flushing chemical lol... the old fluid just looked gray with no bad smell yet, but it was at the right time to change it, since 2/3 the miles on the car are highway miles, so it's easier on the fluidIn the owners manual for my 2016.5 CX-5, in the Maintenance Schedule section, it mentions the transfer oil and the rear differential oil.
When the transmission is breaking in, in particular, and throughout the life of said transmission, fine debris will accumulate from the following sources:
- Planetary Gearsets: The primary source of fine metal shavings. They consist of multiple gears (sun gear, planet gears, ring gear) that are constantly meshing and rotating under load. Even with proper lubrication, there's always a microscopic amount of friction and wear between these moving metal surfaces.
- Other Hard Parts: Besides planetary gears, other hard metal components like bearings (roller bearings, needle bearings), splines, and thrust washers (which can be metal or plastic, but metal ones will wear) will also contribute tiny metallic particles as they wear over time.
- Clutch Packs (Friction Material): While not metal shavings, clutch packs are a significant source of debris in automatic transmissions. As the friction plates engage, a fine powder of friction material (which can be dark and gritty) is shed. This also accumulates in the pan and filter.
The bottom of our transmission pans have a strainer. It plays a crucial role in separating this fine debris from crucial transmission components and the fluid circulating through it. This sludge material will first begin collecting on the magnet. Then, it will sit at the bottom of the pan. Eventually enough of it will accumulate to make its way past the strainer and contaminate your transmission fluid. Allow this process to continue, and eventually you will see transmission wear, then damage, then complete failure.
Therefore, you cannot simply deduce your transmissions condition as "fine" without seeing what the bottom of your pan looks like.
The pan in my AT was dropped at just over 160,000KM. The bottom of the pan and fluid was dirty, not enough to begin placing undue stress onto the transmission,(I think.) but not far off either.
Regarding manufacturer suggestion not to service your transmission. What do people do when their transmissions act up? Bring it to the dealer. What does the dealer say? thousands of dollars for a new transmission.
They pull yours out, refurbish it, swap another refurbished transmission in from another unsuspecting customer, make thousands of dollars off their "recommendation."
BMW recommends that the fluid is lifetime. Sure it is, as long as you don't drive it! ZF, the manufacturer for nearly all of BMW's transmissions on the other hand states: "ZF recommends a oil change at regular intervals for its transmissions, especially In operating conditions with high temperatures and loads, or with unknown vehicle use in the past."
A failing transmission (which, if not caused by a defect, will often be due to contaminated fluid and will not begin to show symptoms "in advance" of something going wrong. In this case, it will begin happening after you have driven for long enough with significantly contaminated and degraded transmission fluid.
In short, and not to sound like a broken record here, but I reiterate that these pans can and should be dropped for very good reason. If you want to know what condition your transmission is in, this is non negotiable. Simply doing regular transmission fluid flush and changes will not clean out the gunk sitting at the bottom of your pan.
Some might say it is, I would greatly advise against it, no such thing as good enough in my book. Cars are expensive. All you need really is a dongle to plug into your OBD2 port and a scan program on you phone, might cost you under $40. And I wouldn't use the Ravenol to mix with what's in there, though I know it's very good brand name oil (used it in my engine). If you are going to just match what comes out, make sure it's cold before you measure it. ATF expands when warmed up.OK, foolish question here, especially when I know what the formally correct answer is.
I have a 2020 CX-5 Signature that is at 32K miles. Bought it new with one mile on the odometer. Obviously I don't drive a lot, although rarely less than 20 miles per round trip. Once or twice a year long road trips. FWIW, my lovely bride and I have always sold our cars with 250K+ miles on them (or had them towed away), so I'll most likely have this CX-5 for a while longer.
I've changed transmission oil on Toyotas before, always using a scan tool to measure transmission temps so I can put in the correct volume of replacement oil.
I don't have that tool anymore and would prefer not to purchase one again for the once/twice it will get used again in my lifetime. Is my assumption that bringing the transmission up to temp, then doing a drain and refill (using Ravenol ATF FZ) with the amount of fluid that comes out, is MOST LIKELY good enough?
