1
151614
2024 CX5 Akera 18” wheels and factory Toyo tyres.
Winter here in Aus right now, so cooler temps than usual. Todays max about 23C and overnight min 17C. Yeah we do it tough here in winter LOL. But it did get down to 5C early one morning a couple of weeks ago.
Went for a short drive this morning, the first time the car has been driven today, got about 4km and the low tyre pressure warning sounded and light came on. Was only about 500m away from my destination so thought I would check the tyres as soon as I got there. But after about 30 seconds the light went off and no more alarms. Tyres looked OK when we arrived.
Drove home again later and no warnings. But checked the tyres a bit later and found:
FR - 36.5psi
FL - 35.0 psi
RR - 36.5 psi
RL - 38.5 psi. (This tyre had a puncture repair done a few weeks ago and I suspect they pumped it up to around 40psi)
So a 3.5psi max variation between the lowest and highest pressures. Maybe when the tyres were warming up after the overnight cool temps it triggered an alarm momentarily due to variation in pressures between the tyres??
Does anyone know the point at which the low pressure alarm activates? Is it based on the variation between highest and lowest pressures across all tyres?
Of course I have now inflated them all and set back to 38psi which is where I normally run them.
FR - 36.5psi
FL - 35.0 psi
RR - 36.5 psi
