What have you done to your Mazda5 today?
Pumped gas today while doing a delivery, as soon as I was leaving at the stop sign, I hear a thunk from the front followed by vibrations and very weird noises from the engine. Immediately pulled over and popped open the hood
Looks like the engine/torque mount on the transmission has left the chat.
Very slowly limped the car back to the gas station to be towed in the morning.
Yeah it happens. If you're brave and have the tools, you can fix it where it sits.
Jack under the transmission, push the motor up
Remove the battery and battery box. This also entails removing the PCM, as it rides on the battery box.
After the battery box is removed, you'll see a black plate, remove that.
Now you see the prize! Swap out the mount and put everything back together.
I thought about that, but none of the parts stores close by had the correct mount in stock, so I opted to just get it done today.
That sucks!
Good call limping it and then parking it. A lot of people would have just kept driving and caused some other problem.
Hope it gets back on the road soon!
Did you notice anything before it failed, like, slightly more excessive vibrations than usual?
I'm doing a proactive replacement of rear and passenger side mounts and this makes me think about replacing all four at this time.
That sucks!
Yeah, I have seen people drive on bad mounts before when I have had to work on some peoples cars. Dont know how they do it it or why.
That was the strangest thing, the car has been driving fine all day at work. Car was not making any noise or vibrations from the front. There was a tiny bump in the road at the stop sign, and after stopping and then driving over it, while turning left, it just made a clunk noise and started vibrating.
Searching for the donor when suddenly I see this:
Note something? I wonder, what's the story behind these two.
Another weird noise, vibrations, pop the hood story...
An hour into a 9hr drive on interstates, I noticed a hammering noise, along with vibrations in pedals, steering wheel. Pulled over, popped the hood, and expected to see the sepentine belt fraying, or a mount failed, but found nothing weird under the hood.
When I told my other drivers on the road trip that I was gonna have to go into limp mode was when they remembered to tell me that a few days ago they'd seen a splash panel under the driver seat (had lost it's clips) was hanging down and now it flapping hard in the 70mph wind. 🤦‍♂️ My revenge was, as they were the largest clips I could recall, was to take a big enough clip out of their trunk liner.
The moral of the story; the engine milage may be low but plastic still gets brittle!
I finished my 5sp manual transmission on my 2010 for the 2nd time.
Mazda updated the clutch fork and release bearing at some point. So when I bought the Exedy Kit. It came with 2 release bearings. If I was smart enough I would have read into that a little bit more, but I didn't and I installed a release bearing included with the kit that had more play than the stock bearing. Thinking it was "just the way it's supposed to be". FYI, I did call Exedy and the tech said it was normal. Well....it made excessive noise and my wife was not pleased.
I tore it all back down and used the OEM updated clutch fork, pilot hearing and release bearing. Very little play on the snout of the transmission. The sound is reduced significantly and the car shifts great.
What I am now realizing is that there are collar shaft that can increase the size of the snout by a few mm for worn out snouts. I imagine that another mm or two would have made the bearing noise imperceptible.
I also did a throttle body cleaning which fixes the rough idle.
That's a lot of clutch work!
MAF sensor is always worth a clean anytime you're in that neck o' the woods. Does a lot for rough idling. I've even had my 5 conk out driving down the road at low rpm in top gear from gunked up MAF. Now I'm a little fanatic about them.
Agree it's always worth a clean while you're in there (provided you're using the right chemicals – easy to damage otherwise). I did the same.
Crazy that it got that gunked up on you, though. If that happened to me, I'd suspect a leak somewhere upstream of the MAF (e.g. crack in the plastic, airbox not properly closed, filter seal torn, etc.), or that someone sneakily swapped out my Mazda OE air filter for a bad aftermarket one...
Well it had 15 years and 85k on it and never cleaned before, and we have nasty pollen levels every year. It was enough build up it was reading 13°F off and would even have the car stall at min rpm in 4th. It'd always had fresh OE filters. The throttle body was relatively a lot cleaner.. so the idea of a switch-out fits. 😔 I wouldn't put it past some of the jerks that used to work in the local dealers shop. The kind of jerk that actually tried to "Johnson rod" me... I kid you not.
quick question, what about k&n, claiming to have better airflow? Is this a good filter?
Passes more air, AND passes more dirt.
I'll take less air and less dirt, because it's not a track car.
Ditto.
Also the designers are gonna have allowed for the full range of air mass required across the full RPM range, and the onboard computer controls the air precisely. Changing the filter to one with less filtering/lower resistance isn't going to net more air into the chambers.. but it will be dirtier air.
K&N makes far better filters than a lot of the crappy aftermarket brands out there, and they have a huge variety of sizes and shapes in their catalog. But they're not better than OE.
When a K&N filter is fresh, OR when it's cleaned and re-oiled absolutely perfectly, it'll be comparable to a mediocre OE filter.
The problem is, you will never ever be able to clean and re-oil it absolutely perfectly. So, at some point you will end up with worse flow than OE, worse filtration than OE, or both – probably both, as @theblooms said. Or you could just replace it instead of cleaning and re-oiling it... which you'd have to do at shorter intervals than with an OE filter, so it's more money and work for no reason.
Best-case, yes, a K&N might be able to flow slightly better than an OE filter with comparable filtration. But that's where @dlarkin_dc's comments come in.
Man, I hate having to chase down AC issues. Noticed a really bad wobble on my Radiator fan. I assume it got so bad it actually bent/broke the plastic tab on the radiator, so it wont even set back in place. Now it is just zip tied in place for now while I wait for a new Fan/Shroud to come in.
But recently as the temperature has gone up outside, my AC has been going out off and on. There is no pattern to when it decides to kick on or off. The car's temperature has been normal(well below half) during this ordeal. My guess is probably the clutch on the compressor is finally going out(167,000 miles). I can hear it click on when I turn it on and off, but sometimes it doesn't once the car has been driven for like 40+ minutes. Then I noticed when the AC was running and blowing cold, my car was pouring out water/moisture from under the passenger side spout. Car would make a pretty good size puddle after sitting in place for a few minutes.
Also back in May we put more compressor oil and topped of the freon, and the freon was not even low and was holding proper psi.
Just delaying the inevitable of having to replace the entire AC system. But I think it is just getting to that point considering the age and mileage of the car.
Replaced the passenger engine mount. It was surprisingly easy with a floor jack and piece of wood.
Less engine movement when starting, and the vibration when stopped in D (that I was so concerned about here) is gone. It was not a faulty torque converter, not any of the sensors, it was as easy as 1 engine mount.
Interestingly, I also almost accidentally discovered that keeping an old (not even functional anymore) OBD2 tracker dongle from metropcs was creating problems with electrical system: persistent parasitic load, messing with real-time obd2 reader etc. Not to mention I would never be able to pass smog check with that device plugged in.
I really need to find a solution to mounting my radiator fan to the radiator. The current radiator is an aftermarket one, so that means the tabs for the radiator aren't quite up to spec. I push the shroud on and it seems to want to set, but it wont "click" the tabs into place, so it isn't fully secured.
I don't know if taking a sanding stick to the hole to make it wider will actually help, because I feel like the actual tabs on the radiator don't have enough of a lip on them. So even if it would somewhat click on, I feel like any bump would have it pop right off again. I really wish the shroud and radiator had a hole or screw area to thread a bolt into it.
I even looked at ways to just zip tie it, but there isn't any good spots on the shroud or up top for me to even think about strapping it down.
Oh, and to add insult to injury, when I was moving the upper breather hose from the fan shroud, to move it out of the way, the plastic bit on the radiator fill neck snapped off. Not even snap, because it didn't make any noise. It just finally let go. So I am ordering an Amazon fill neck, since its the only one I can get "quickly" and by quickly I mean Saturday.
This morning, I noticed the power steering pump had started whining a bit louder than usual - even while driving straight. Figured it was time for a power steering fluid flush. It turned out to be a fairly straightforward job, though a little messy.
The last time I changed the fluid was around 4.5 years ago, so this was definitely overdue. The old fluid was pitch black and had a strong odor (not burnt, but definitely not fresh). It took a couple of flush cycles to get everything cleaned out.
While I was at it, I replaced the original return hose clamp with a screw-type clamp for added security.
For the fluid, I used: Castrol Transmax ATF/CVT Universal Automatic Transmission Fluid, Size: 1 Gallon, Part Number: 15FD52
Used nearly the full gallon.
Everything’s running more smoothly now, and the pump noise has noticeably quieted down.
Giving myself a small pat on the back - this car continues to be surprisingly DIY-friendly!
Maybe not my Mazda, but my buddy grenaded his Audi and picked up a Mazda3. Continues to be surprised by how much easier it is to service lol 😅
Glad to have a friend join the Mazda gang!
