How about a battery cap check. I bet 50 cents that your battery will fail the test.
I'm guessing this would have been covered by the initial GR8 test, but I have no idea. If I get the chance, I'll try and see.
A car that is sitting for a couple of weeks while repairs are being done can drain the battery down quite low and it will take a good long drive to charge it up again.
So I would first give the battery a solid overnight charge using a 10-20amp charger. A good charger will show you when the battery is fully charged. Victron are top shelf chargers.
Have you got a charger like that, or can you borrow one from a friend? Might save you the cost of a new battery!
The other thing is the tightness of the battery connections, which may have been undone when the repairs were being done. They need to be TIGHT. A less than real tight may make for a poor connection. So get a spanner on there and get them nipped up nice and tight!
Depleting the battery once would not have killed it.Would it have killed the battery by depleting it once?
The same thing happened with my Honda CRV, and it doesn't have the same issue. Since I work from home, I drive Mazda less (every 2-3 days), so I'm wondering if this is a factor.
Driving every 2-3 days should not be a problem, even longer should be fine. If it is a problem then there may be something in the car that is depleting the battery, perhaps an accessory like a dash cam that is set up such that it is always drawing power.
I've had 2 CX5s, a 2020 and currently a 2024. Both had dash cams, both were kept unlocked at home, neither one had any problems with the battery.I immediately turned off the dashcam's parking mode after it had depleted it once because the same thing had already happened in my CRV.
I've read a lot of posts in this forum where Mazda owners have gone through multiple batteries in a year or two, especially for cars in my year 2023.
I'm wondering if the keyless fob has anything to do with this. Mine doesn't work well. About a third of the time, my doors won't lock. And I just read a post where the battery drains whenever the door remains unlocked. So I'm wondering if this has been killing the battery.
If this is such a problem, I'm kinda' mad at the dealership for not mentioning this. Maybe, they are trying to push all of the blame onto the body shop owner because they know that Mazda isn't going to pay for this.
5A is good for keeping a well charged battery topped off. But not for charging up a depleted battery. It would probably overheat and cut off.Moonlighter, you mentioned getting a 10A Victron charger. Do you think https://www.amazon.com (commissions earned)be sufficient? (I'm trying to save a few bucks.) Would a 5A simply take longer to charge?
I don't know if it matters but I'm probably going to get the following battery.
Best to get at least 10A or better still 15-20A. I have both a 5A CTEK that I use to keep by boat’s batteries topped off, and a 20A Victron for times when I have to charge up a low battery.
IMO the 2 best battery charger brands, by a mile, are Victron and Ctek. I know that Americans love their NOCO’s but IMO they’re not in the same class as those two. See too many NOCO’s failing for my liking.
Do you not have a battery or auto parts shop near you that will test the battery for you?? Most do it for free or a small charge. And BTW I have seen battery testers give false readings more than once….. but anyway, you have one of three things going on IMO
- bad battery (most likely)
- alternator not charging properly (next most likely)
- a parasitic drain somewhere (possible but least likely)
A good auto electrician will diagnose this in 10 minutes.
Is there a brand you'd recommend?@Moonlighter - I can’t speak for automotive Victron products but in solar arena (US Market) the brand now gives me pause from consideration with failures (forums) in recent years… it seems to no longer be a “sure thing” and reliable brand
Interesting info about how dashcams draw power even without parking mode.I've had 2 CX5s, a 2020 and currently a 2024. Both had dash cams, both were kept unlocked at home, neither one had any problems with the battery.
If not on a switched circuit your dashcam will be consuming power even though you've disabled parking mode. I would disconnect the dashcam until you've resolved the problem with the battery, just to eliminate one potential cause of the problem.
There are auto part stores nearby but the car is currently at the body shop. Is the equipment at the auto parts store different than the GR8 at the dealership?Do you not have a battery or auto parts shop near you that will test the battery for you?? Most do it for free or a small charge. And BTW I have seen battery testers give false readings more than once….. but anyway, you have one of three things going on IMO
I'm going to do this. This would eliminate the possibility that the body shop screwed up. Would a parasitic draw test determine a loose ground wire?A parasitic draw test needs to be done!
I went to another guy and he's also thinking that it might be a battery issue. He doesn't think it's a ground because the symptoms don't match up. He did perform his own battery test but it came up with weird results. The battery wasn't fully charged though. The test stated that the alternator was faulty.The purpose of a second battery test is the same as getting a second opinion from a Dr. - because the first test may have been wrong! As I mentioned, I have seen professional level battery testers give false results on more than one occasion. Mazda’s tool is likely no different. A second, independent test will either verify their results, or not.
I'm probably just going to replace the battery and see what happens. I'd like to thank you and everyone else here for the help. Really helped.
This could be the problem, and even a new off-the-shelf battery can be run down from just sitting. A good battery shop will fully charge the new battery before it's installed.The battery wasn't fully charged though.
Absolutely! I have found that new batteries are rarely fully charged when installed.This could be the problem, and even a new off-the-shelf battery can be run down from just sitting. A good battery shop will fully charge the new battery before it's installed.
I don't know much about cars. It was the guy who said the alternator is probably fine. He inspected the copper coils and stated there wasn't any discoloration, which usually indicates a faulty alternator. He also said that since this is a new car (1 year), it's probably not the alternator. I'm just going by what he said.Is there a reason that you discounted his diagnosis of faulty alternator?
Maybe I misread my multimeter and it was 5 milliamps? But then wouldn't 5 milliamps be a bit too low?With that kind of draw, you should be able to find the problem by touching relays with your hand.
Your multimeter has a fuse, to prevent being destroyed from situations of too much current, just need to replace the fuse with one of the correct rating. It may have come with a spare fuse.I burned my multimeter so there is no way to recheck it until I get to buy a new one. I'll let you know.
