Money grab. I am so confident that they were not.Reading all of that makes me wonder if something is really wrong with my car.
At 15k miles it had all its pads worn out.
Use the procedure that involves holding the parking brake switch.For CX-5 model year 2022.5 Turbo Signature model, Canada.
The brakes I understand need to be put into Service Mode, but the procedure from what I have seen on utube is different from older model years.
A special scanner tool may be required to pull back caliper pistons, otherwise the gears in brakes motor will break. It appears that existing scan tools used for pre 2002.5 models do NOT retract the 2022.5 brakes.
If anyone has done a brake job on newer 2022.5 or newer cx-5 let me know.
My cx5 only has 27,000km so not due yet.
The model changed mid year for cx-5 in 2022.5. Mine is a October 2022 manufacture date.
Which model year of cx5 did you perform this on?Use the procedure that involves holding the parking brake switch.
I did front and rear on my 2023.Which model year of cx5 did you perform this on?
Did you do rear and front brakes?
Wow, you must do a lot of milage to replace brakes in one year. How many miles did you have?I did front and rear on my 2023.
I replaced the factory pads with Akebono ProACT at 3,000 miles. I now enjoy much less brake dust.Wow, you must do a lot of milage to replace brakes in one year. How many miles did you have?
I have 27,000km but no dust on my rims. I do service my brakes yearly, but not replaced anything yet.I replaced the factory pads with Akebono ProACT at 3,000 miles. I now enjoy much less brake dust.
Proof or it didn't happen.I have 27,000km but no dust on my rims
I assume your greasing your caliper pins each year and cleaning out the dust. The caliper head is subject to extreme heat, hence the brake fluid is subject to being weak or contaminated, plus rust and dirt can seep in from piston rubber, hence I bleed the brakes, every two years to get rid of some old fluid. Never had brakes issue in over 50 years. Just looking at brake pad thickness alone is not enough. The dealer wanted over $400 to grease the caliper pins on a 12 month old Mazda! It took me 10 minutes at best to do.I am not a maintenance geek and I am quite certain that my car could use some better care. I still have the original brake pads in the front, they are getting close to red, still in yellow at the last inspection. On the aft wheels, now those were on red so I replaced them last week. So, I don't know how some people drive or how I drive, or maybe I am just a suuuper ignorant caretaker, I don't know. All I know is that my car is going strong towards 165.000 miles with the original brake pads on the front wheels. Soon to be replaced but I am just using my car as an example. Good or bad, who knows, I don't wanna know.![]()
