2024 CX-5 Turbo Sig Bose - Amp Roll off/EQ question
Hi, I got an LC2i > JL JD500/1 installed on my car.
Installer used the rear speaker signals.
My subwoofer doesn't play the 33hz note in the song "Decaf - White Clouds".
Question: Does anyone know if the roll off of the rear speakers is identical to the Bose sub? I am debating on swapping the LC2i inputs to be from the Bose Sub wires.
Sub signal and front door speakers appear to share the same bass frequencies.
I didn’t measure the rear door speakers.
Pictures are attached are the speaker level signals (electrical).
Upvote 0
Thanks for this. It is greatly appreciated. It does confirm though, that the frequencies impacted are identical.
If this is the literal signal measurements and not speaker output:
Sub vs Front
@50hz +2dB
@40hz +5dB
@31.5hz +5dB
@25hz +6dB
I shall swap to the sub signals for the inputs to my LC2i.
Upvote 0
