FukuokaKid
2024 CX-5 Turbo Premium
Aloha CX-5 Peeps!
I just recently picked up a '24 Turbo Premium and I've been following a lot of your projects and issues. There seems to an only a few spring choices here in the US. However, that is not the case in Japan.
I wanted something to get rid of the fender gaps but still maintain the relatively plush ride. I was originally set on getting either AutoEXE's Lowdown springs or their CoilOvers. However, their springs only have 30mm of drop. On top of that, spring rates are raised ~10%. AutoEXE's coilovers require that you purchase parts from the Gen2. Others manufacturers that had more drop, like Espelir, RSR and Tanabe, raised the spring rates even more. Then I came across this small tuner shop in Osaka called, Odula.
From what I understand, Odula wanted a drop similar to the Eibachs but maintain the performance and ride quality. So, they had Eibach custom wind springs to their specs.
For the TLDR version, here are the specs...
SPOLUX LOWDOWN SUS (KF015)
Front Drop: ~40mm
Front Spring Rate: 3.26 kg/mm
Front Free Length: 352mm
Rear Drop: ~40mm
Rear Spring Rate: 3.49 kg/mm
Rear Free Length: 336mm
AutoEXE lists the KF AWD Turbo stock spring rates as 2.94F/4.11R.
Now, this actually goes against everything I know regarding performance... Usually to reduce understeer you stiffen the rears and soften the front. This is doing the exact opposite. I don't know anything about AWD suspension tuning so I hope this does not turn out to be a disaster. The only thing I can think of is the softer rear springs will make it easier for the swaybar to do its job.
The reviews that I found were all positive and customers said performance and ride were improved. I had to try them and here they are.
I hope to install them soon and will update with my opinion soon after. I'll probably follow CorkSport's instructions regarding trimming the bumpstops as neither bumpstops nor instructions were included.
Did I mention that they are a really bright Orange?
Anyway thanks for reading and I hope someone else can find this info useful.
Mahalo!
Front Drop: ~40mm
Rear Drop: ~40mm
Mahalo!
