2024 CX-5 GS Ride Quality and Noise Levels
The correct size if converting to 16" wheels would be more 225/70-r16, not a 75 sidewall.
It would help, but whether it is worth the investment of time and money to switch to an sidewall ratio of only +5 is questionable. I'd say try new tires for your OEM wheelset instead?
I got about 40k miles out of the G91s and then switched to Conti LX25. I am sure new tires are always quieter, but I don't know if there was a huge difference in either ride or noise. I would say the G91s were pretty good for a OEM tire.
I have Conti TrueContact Tour on my 6:
Overall a good tire in every metric, except for wet grip.
What size? 🙂
225/55-r17
As I mentioned, for the horrid roads we have here in Ontario, a 55 sidewall combats everything but the worst of it quite well. I wouldn't mind a 60 sidewall over some sections of road here, but anything thicker than 60 and I think i'd start to lose some of the handling response I expect from my vehicle (around corners.)
Just some food for thought.
225/55-r17
I might get 235/70R16 winters like Michelin X-Ice Snow or Continental VikingContact7.
I want to get 225/75R16 snow tires but theyre all truck or van tires like the Michelin Agilis Alpin or Vancontact. Is that a bad idea?
It fits my car and will provide more cushioning but it's not for SUV 😉😅🤓🤪
I might get 235/70R16 winter (tires)
A 235 width tire will hardly mount any wider onto a 7" wheel than a 225 width. For the OEM 7" wheel width, you're best off sticking to 225.
So if you do purchase a wider 16" wheel (such as 7.5 or 8" wide with the correct offset to compensate,) a 235 width tire will fit fine, but you would not want a total tire diameter any larger than this.
As I mentioned in a previous post, these tire sizes are too large for your car! Yes, it is a bad idea.
It fits my car..
It does not.
Refer to this link here:
assuming that you have went for a 16" wheel for your winters, and you've selected the correct size wheels, you want to make sure that the total diameter of your new tires closely matches the diameter of your OEM tire - (approx. 724.3mm.) 225/75-r16 would be significantly larger in diameter than this, and likely would not physically fit into your wheel wells. If they did, it would still be much too large for the vehicle's design.
In short, if you go 16's, stick to a 16x7 et 45 wheel, and use 225/70-r16 winters.
It does not.
That sucks thanks dude I'll stick with 225 70 16.
Chocolate 🍫 made a post on fat tires and did 225 75 16 😭
Can I use 235/70R16? I don't know 😐
This guy used 235/70R16 but he's no longer a member as he got banned.
Ok sorry for the conversation I just DMed him this week. Wow he's no longer here? I was getting replies. Ok thanks everyone 😊
225/70/16 I think or even 235/70/16 if I get bigger rims
If you get a 7.5 or 8" wide wheel, with offset to compensate, then sure! But, I don't see why you'd need to go wider than 225 on this car.
I'm fully tuned on 91 octane, so while I wouldn't mind the extra grip of a 235 tire, 225 is plenty, especially for the heavier and AWD cx5.
Again, even if you can fit 225/75-r16 on this car, makes nooo sense to. Don't overdo it! Going for too big of a tire diameter wouldn't get you desirable driving characteristics.
Ok sorry I'm just trying to cushion the ride and make it comfy. 😮‍💨😂 Might do 225 70/75 16 thx for input 😃
It's strange reading about the CX5 suspension being too hard when it is the softest of all of the current Mazda lineup. When I hear ride complaints about the CX5, it's usually about the ride being too soft or that it has too much body roll
It's nice but my roads are awful. Edmonton Alberta Canada 🤭.
Very bumpy though 😭 I need cushioning
Lol yes, they actually softened the suspension on the Skyactivs as much as possible while trying to retain as much handling as they could. My Skyactiv 6 in comparison to my buddies first gen 6 had more body roll when cornering hard, but enjoying the chassis within reason resulted in great response.
The max I will do is 235/70/16 for winters. Hopefully ice or snow won't build up in brake or wheels and is enough to thaw.
And the slightly wider 235 can still plow through packed snow? I heard narrower is better but wider tires lends to better stability or handling?
But it's the optimal size and within 3% error (1.53). My speedometer will read 1.53% slower than OEM 17 and get slightly worst mileage but I gain in cushier ride and cheaper rims/tires.
I've been given answers to my issues with a firm ride. Going to premium tire or 16" (235//70/16) is the cheapest.
The other option is air ride coilovers. The only shock and strut options I see is Bilstein B6 but it's sportier so stiffer than OEM.
I'd like to see more options for shocks and struts. My 2014 Mazda3 has Koni Special Active and the ride doesn't beat you up like a CX-5 on bad roads. Too bad Koni didn't make it for the KF gen... 🥵😭
Hm - I found 5x114.3mm, 16x7.5 or 16x8 steel rims. The only problem is centre bore is a bit bigger than OEM. Isn't it supposed to be 67.1? I'm getting 70+
