AL Cx5
2024 CX-5 Prem Turbo Tuned Lowered Forged Wheels
Today I installed a WIX Filter Minder, FM, a gauge that measures the pressure drop across the air filter box inlet to the clean air side of the filter media.
I installed a WIX part # 24801. It took longer to find my 11/16" drill bit than to install the gauge.
If you have wondered when the filter needs to be changed, this product has been around for many years on heavy duty trucks and equipment. I've used one for 18 years on my truck to determine the air filter condition. It also indicated the air inlet to the filter box was undersized. We fixed thar issue on my Cummins turbo diesel.
I still have the OEM air filter that came on the car with 5,700 miles. I ordered a new air filter tonight to have a clean air filter comparison.
It appears Mazda is using the same air filter box on the turbo and NA engines but change to a deeper filter media on the turbos. Deeper filter pleats will pass more air.
Normal city driving the FM gauge didn't move. At WOT it measured 15" water column total pressure drop from the inlet to the filter and through the filter media.
I'll pull a steep hill nearby on I20W at 70 MPH on CC and let her eat. It will be interesting to see if this indicates the filter box is over powered under normal driving conditions.
The practice of using the same air filter box NA and Turbo is not all that uncommon. Ram used the same air box on their 3rd Gen 5.7 Hemi and 5.9 Cummins Turbo Diesel. We notice the same deal, the filter minder went to 15" pressure drop driving normally. Over the years folks have found ways to improve air flow through this box. I settled on a 3" hole in the bottom to tubing that increases to 4". I inserted a backdraft damper in the 4" and tuned the box so the damper starts opening at 4 PSI boost. Without this damper, we lost some low end torque. This damper acts like a variable runner inlet found on some NA engines. I tested with and without the damper and found the damper helps when under light load, solo.
I like the design of the Mazda air inlet keeping water out of the box and allow cool air in. I would have blamed the filter media first if I didn't have experience on another platform. We tried K&N drop in filters and didn't see any change in MPG or the FM. When we opened up the air box, we saw and felt a difference. Maybe the Mazda box inlet is undersized.
A 4000 RPM NA 2.5l at 0.05 bar pulls 157 cfm.
Turbo at 4000 rpm at .9 bar pulls 285 CFM or 45% MORE air than it's NA cousin.
The inlet tube to the air box is 3" diameter. Velocity NA is 3,205 FPM, Turbo 5,816 FPM. Again 45% higher velocity. The air changes direction several times to allow water particles to fall out. Holes are in is duct to allow water to exit. 5800 FPM entry velocity sounds very high. It is blasting dust particles across the box into the media. I found bees and flies in the media and no heavy dust in the bottom of the box like I've seen on some NA air boxes.
Velocity through the filer media is much lower and may or may not be the problem. I might order a "high volume" air filter to run as a comparison to a high filtration filter.
The first pic is driving around town, didn't move the gauge and the second is WOT in second gear to 5000 RPM measured +15" wc pressure drop.
