"Service Past Due" message appears (CX-5 2019)
... Also do you have the maintenance interval set to regular intervals or is it set to the “smart/flexible” interval. ...
It's set to flexible. It always does 7500 miles though. I think I tried fixed once with no difference. I'll try it again just to see.
I believe at least CX-9 and CX-5 after about 2019 model year. I thought it was pretty standard since.
That instrument cluster looks nothing like what I have in my 6, or what I have seen in most Mazda models.
What is it from may I ask?
That's our 2019 cx5 signature with the 2.2 diesel
Does anyone know why this message started appearing on my Mazda CX-5 2019 only when I turn it on in the morning?
Is there a way to clear it and not let it appear anymore?
I serviced the car last month at the dealership.
When I go into the setting it shows there is no service that is due and under the Warnings setting it says "no warnings found".
Thank you for any insight.
Here’re 2 related TSBs for your problem. The second one is for Gen-2 CX-5:
TSB 01-008/19 - ENGINE OIL FLEXIBLE MAINTENANCE NOTIFICATION DOES NOT WORK
TSB 09-037/18 - OIL MAINTENANCE MONITOR RESET CONCERNS
Happy to report I was able to fix the annoying "Service past due" issue. Thank you to anyone who helped in this thread. What I did was go into the setting: Oil Change - Setting Inteval - and changed it to Fixed instead of Flexible
