2014 CX-5 2.2L Diesel problem with 6th gear…Help
Hello everyone, I have had a Mazda CX5 2.2d 150KM 2014 AWD for some time now, I have a problem with the 6th gear, the gear jumps out when I drive faster. Does anyone have diagrams for this gearbox? I will be grateful for your help. Regards
* Translated to English
You can try to replace the gear lube and see. And check the shift linkage to the 6th gear. But most likely the synchronizer for the 6th gear is failing and you need manual transmission removal and tear-down.
