- Canada
I will do this later today. Thank you!
Hope the results are fruitful!
How long were you away from the car during that time?
You tested this on your car? I'm about to test mine while I'm at work, just to satisfy my curiosity lol
That's an assumption on your part. My post assumes that @Ess925 is referencing the car's battery, not the keyfob, but it is written in a way that could apply to either the car battery or the keyfob battery. The portable battery booster recommendation was due to the car's battery drain concerns, but it's also just good sense to carry a portable battery booster in the car.
It could be the case, which is probably why the OP posed the question in the first place. "Smart" keyless systems work on a process of check and verify. The keyfob is always "on", sending out a weak signal. When the keyfob is close enough, the car interprets that signal (the check) and waits for a request from the keyfob to verify an action (engine start, unlock door, etc.). If there is no request made, the check times out, and the process repeats. This is what drains the car battery, if the car doesn't have a system in place to deactivate a keyfob in close proximity. Some new cars have this system in place, and some don't.
@Ess925, if you want, you could test your use case right now.
Turn the car off and leave your keyfob in the cupholder, then lock all the doors. The car should beep a bunch of times to remind you that they keyfob is inside the car - ignore this and make sure all the doors are locked. Ensure your other keyfob is well out of range of the car.
Wait an hour or two inside the car, ensuring that you don't touch the keyfob at all. Now try to start the car without touching the keyfob. If the car doesn't respond, or you get a key error, pick up the key and drop it in the cup holder to "wake" it.
Try to start the car again. If the car starts, you have a keyfob that will sleep and not drain the battery if it's left in the car. If the car starts on the first push, before touching the key, don't leave your key in or near the vehicle because it doesn't have a “sleep” mode.
If you don't want to wait in the car, you can also do this test by leaving the driver's side window open all the way. Just make sure you can park it in a safe place (like a locked garage) and that you can reach the engine start button without opening the door. When you come back to the car later, press the engine start button. If the instrument cluster says "No key detected", you're good to go. But if it says "depress the brake and push the start button" or something like that, the keyfob doesn't go to sleep and you would need to use a Faraday box to block the signal.
No need to get a spare to test it, just take out the 'skeleton' key from inside the fob and leave the main body of the fob in the car.Interesting. I will get a spare made and give it a try. Thanks!
All day... probably 8-10 hours.How long were you away from the car during that time?
No, the opposite. OP said:Oh, and it seems that my assumption was correct, the OP was talking of the fob battery.
I was concerned that the "communication" between the fob and the vehicle would drain the vehicle's battery.
If the fob battery is dead, you push the Start button with the end of the fob (it's in your manual). Then it's in close enough proximity that the car can 'energize' the chip and read it. And no, you cannot start the car without the fob.Mmmm, no, I didn't know that there is a way to start the vehicle if the fob's battery is dead. Wouldn't that mean that the car could also be started without the fob? Please explain to someone who isn't a car person (me)
The OP has to sit in the car for an hour or two? Ok then, good time for a nap, I guess?
Why would Mazda's fobs send out a weak signal at all times? What does that signal do? From a design standpoint, that makes no sense.
Whoops, I see that I wasn't clear. I was concerned that the "communication" between the fob and the vehicle would drain the vehicle's battery.
YoutubeWhoops, I see that I wasn't clear. I was concerned that the "communication" between the fob and the vehicle would drain the vehicle's battery.
Snip...
Pretty sure key fobs don't sleep or wake. They are passive. You push the starter button and the car then looks for the fob. No fob, no start. As someone else said that would be a terrible design.
Thank you!The fob has two devices inside to ID itself to the car and allow it to start.
One is powered and requires a battery and can work over a small distance.
The other is akin to a RFID chip, and it requires no battery. This chip has to be placed in very close proximity to the Start switch. Inside of the area of the Start switch is an induction coil and when the fob is near the energized coil it enters the coils magnetic field and with its own small induction coil the fob picks up enough juice (it works in the same way that wireless charging works for your cellphone) to power the chip and the signal the car is looking for to start.
Don't be surprised if your salesperson knows nothing about the fobs sleep function.Thank you everybody! I ordered a Faraday bag and emailed my salesperson at the dealer to see if my fob has a sleep function. Either way, I should have it covered.
