P0471 and P2262 error codes (CX-5 2.2L Diesel 2015)
Hi all,
I own a Mazda cx5 2.2 diesel 2015 European model, and I read two codes. P2262 and P0471. Because in Greece I don't trust Mazda mechanics, please let me know if you could, what could be. 172500 kms and the engine runs normally. Any idea could be greatly appreciated.
Warm regards from Athens Hellas.
Could be many things. What did you see when you looked up those codes on the internet?
If the car is running normally, could just be a sensing problem.
I saw the engine fault yellow light on the dashboard, the engine running normally and after 100 km approximately dpf message “Soot Accumulation in DPF too high. And did regeneration DPF on her own, following mazda DPF regeneration.
Hi all,
I believe you need a new and improved exhaust gas pressure sensor on your 2.2D, or at least try to clean it first.
P2262 main problem code
Thank you my friends. I really appreciate it.
Hi all,
Did you fix your Mazda,I have got the same problem,apparently need a new engine
