n3rdgen@CS
CorkSport Rep
The CorkSport Turbo Inlet Pipe drastically increases the overall flow potential of your intake system to efficiently feed the turbocharger. This is done by innovative design, maximizing the space available to increase the cross sectional area of the turbo inlet pipe from the small OEM 2.5 inch to a larger 3 inch.
The CorkSport Turbo Inlet Pipe is Roto-Molded to provide fitment for multiple models including the Mazda 3, 6, CX-5, CX-9, CX-30 and CX-50 outfitted with the 2.5L Skyactiv Turbo engine. Whether you’re upgrading your existing CorkSport Short Ram Intake, (with or without the CorkSport Heat Shield) or are getting the combo all at once, the CorkSport Turbo Inlet Pipe is a great mod to level up your build.
With the limited tuning abilities currently available we are being limited by the ECU load limits and controls. However, we are seeing solid gains across the majority of the RPM range; gains of 5-17wHP & 9-31wTQ where measured with a DynaPak chassis dyno with the installation of the TIP & SRI Combo on an otherwise stock vehicle. The kit is currently priced at $249.99
