2016 CX-5 Sport Drive belt and Hydraulic tensioner replaced
2016 Mazda CX-5 Sport & 2010 Toyota Corolla LE
Last December my mechanic replaced the leaking hydraulic tensioner and serpentine belt on my CX-5 sport at about 64k miles with Mazda parts. He did not replace the water pump belt. So, at 75k when I have to get my spark plugs changed, I am going to ask him to change out the water pump belt.
Does the water pump belt have to be a Mazda branded one or can I use any other brand for the water pump belt?
I used a Gates on mine (bought from Amazon. It was a b**** to get on... someone said the aftermarket ones might be a bit tighter than OEM. In any case, it works fine (and you don't care if someone else is doing the work :) )
So it's ok to mix brands of belt? Like for the serpentine I have the Mazda belt, and for the water pump I can use gates or another brand?
NO! One belt may contaminate the other!
Sorry, kidding. Yes it's fine to use diff manufacturers
The Mazda dealership where I go doesn't even use Mazda belts
