Anyone Here Get Their 2.5T Tuned Yet?
TheLion, thanks for the in depth information, its great education for everyone.
I've been a long time K&N user, mainly for the fact that they are reusable, and since I, like you, are an engineer (mechanical) and auto enthusiast, I dont mind cleaning my K&N more often. I have had K&Ns in cars over 200,000 miles with no issues related to wear and more dirt intrusion into the combustion chamber, but I havent done scientific studies either. So Im not trying to disprove what you mentioned, just giving another perspective. Sometimes I just like the slight bump in sound on some engines using a K&N, as one reason paper filters are used if for their sound absorbing capabilities, as OE's try to control sound as well with intakes, not just performance and durability.
Its all a game of trade-offs and how you elect to balance them.
As far as the additional performance I think some here are looking for (cant speak for everyone of course), with their CX-9's, is back to the trade-offs. Some arent suggesting to wring out the 2.5T for the most power you can get, at the expense of lasting only 30K before falling apart, but to shift the priorities. For example, if your like me, used to 14 MPG with my Cayenne Turbo, giving up some MPG's on the wifes CX9 wont be a shock, if I could get a little better mid to top end power. Thats likely what you got with your Ford tune, they worked within reason of the vehicle system, giving up something, but getting a little bit more elsewhere, or negating a top priority they felt the majority of customers want, for another like more performance. And thats why they can back it, its not extreme and within the design space. Heck, some people only keep a car for 20,000 miles, and could care less about durability, but want a little more performance......to each their own.
And at the end of the day, maybe there is nothing left on the table with the 2.5T, maybe Mazda already did all they could and elevated performance in all areas, or had to greatly limit something in another area that prevents any additional gains or even re-balancing of trade-offs, and thats fine, but I think its an unknown to anyone outside of Mazda.
I do agree, you cant just have anyone do this type of programming, and it needs some driveability, durability, etc. backing before Im jumping on the band wagon. That again, is something Ford has the resources to do, or in my opinion, already did when they developed the 2.3 turbo, they just released something different to the market for different reasons, based on different priorities, but knew they could come back to it if customers wanted some more power over another attribute.
No problem. I have no issues accepting the reality that lots of people run K&N filters without any noticeable issues. I have used them myself in the past including a first gen 2007 Focus ST (2.3L Duratec, not the newer turbo 2.0L) that I got with 104k on the clock, put in a K&N Typhoon and ran it til 174k without any notable differences.
That doesn't mean however it didn't suffer accelerated ring wear. It may have been making 3 or 4 or 5 hp less for all I know. Most people can't tell any difference in the seat of their pants if the change is under 10 hp. And over time it did have some minor oil consumption, about 1qt every 4k to 5k by 174,000 miles.
I attached some data that shows why I do not suggest K&N's or other reusable filters. I think K&N's have legitimate application in track cars or weekend toy's that don't see a lot of mileage, but I don't see the benefit for typical daily driver applications.
And I get it that some people want a bit more (I did too). But from everything I had learned modifying two 2016 S550 chassis Mustangs (2.3T and 5.0L V8) and the extremely intensive research efforts I put into it to really understand the designs, I've become much more critical of "bolt on" mods and far more selective. They have a place, but must be chosen very carefully and for the right application.
I really suggest trying the engine formulation first, I think you will be surprised at how much more of a difference this makes vs. a CAI. It's not just power, but engine response is notably improved (not that the 2.5T was bad, but it still was a bit lacking at times). I think this is much more beneficial because your not increase wear but reducing it while also increasing torque output by reducing losses on bearing surfaces and supporting higher film strength of the oil during hydrodynamic operation. It's a win, win, win other than the investment cost.
Just make sure your engine is broken in fully, otherwise you can stop the break-in process and cause issues (aka on a brand new engine, the ring's won't seat properly resulting in oil consumption issues, low compression etc.).
I waited until after 10k miles to apply the DLC coating to my CX-9 and just recently did the transaxle at 28k since the transaxle formula has been in the development phase for the past two years and has only recently become available on kickstarter. You can use it in wet-clutch applications as well (bike trans), but make sure to go easy on the clutch until the wear in occurs, otherwise you will cause the DLC coating to form on the clutch disks and it will slip = not good. I would say even for auto transaxle's do the same, just drive normally until the wear-in is complete to avoid any possability of it form on the torque lock disks (which would cause slip). Other than it, just it will form on wear surfaces as you use it over the first 500 miles.
I've also looked into competing DLC technologies, primarily Hexagonal Boron Nitride or HBN (used in Archoil and Liqui Moly CeraTec) and found that HBN has some issues (requires a lot more physical material to form the DLC coating and is susceptible to absorbing water which is a big issue in an engine) despite also achieving similar anti-wear and super lubricity properties to Synthetic MSH. Both Archoil and Liqui moly also use chemical friction reducers you loose with your oil change, so you have to keep adding them back in, they may also settle in the pan. The HBN DLC film that forms from Archoil / CeraTec will last around 30k miles however.
TriboTEX is ONLY a DLC coating with a service life of around 40k in an engine or 80k in a transaxle / manual trans (two different formulas). It really is the ideal In Situ DLC material for ICE applications because it does just that one thing and does not alter your motor oil's formula (risk of increasing wear or friction with you use additives and you don't know how they interact with the motor oil's additive package).
One last counter point, as you noted, none of these dyno tuning shops have the resources to test to the level of the manufacturer. Not one of them is going to achieve the same level of reliability except maybe Ford Performance, who is an exception because they have access to Ford's engineering data, engineers and equipment etc. It's a bit of a unique business model that's a Ford only type of deal. No other manufacturer is currently doing that to that level. Most OE performance devisions, e.g. Chevy Performance, only offer suspension and exhaust upgrades or cosmetic add-on's.
But I prefer what Dodge and Chevy do anyway after having gone the Ford route, they give you more out of the box but don't offer any re-mapping of the ECU. Yes some of them do offer "OE like" CAI's, but at least we know those have been tested to not cause issues with the MAF readings and lean out the engine. Yet again I digress and promies to stop posting so much...or will I? He he. There's always so much to say!
  • Debunking the K&N Myths - Why OE is Better.pdf
  • TSB_oil_filter_particle_size.pdf
Also please note that I do not necessarily agree with the author of the article showing ASTM tests on the filters in that he states K&N is doing dirty business all for the sake of profits.
I believe they most likely believe in their products and there are some benefits, it's an old technology from the 1970's and is still the same filter today essentially. But just because there is a benefit in one area does NOT mean there are no draw backs in other areas. With filters, your always trading something off, so balance is the key. At what point does the flow restriction become an issue with engine performance? How fast does the filter get dirty? How much does it affect engine wear? What is the application (daily driver vs. track car etc.)? All things to consider.
Here's a great article about diesel engine wear vs. particular concentration and size (both matter): https://www.perkins.com/en_GB/resources/meet-our-experts/julian-wood/diesel-engine-filtration.html
Another note, I don't necessarily hold that you have to use OEM, but don't go cheap on filters either! There are many sub-par aftermarket filters that simply don't do as good of a job as OE, but there are some that surpass OE. Just make sure there's valid info other than "well I've used it for xxxxxx miles and my car is fine...". For all you know that guy's car may be in the shop next week for an engine rebuild due to compression loss and oil consumption issues. On the net, everyone is an expert ;-).
Here's some more data: see attachments. BTW the Weveden test of TriboTEX is basically the "test to pass" when it comes to EP additives. It is extremely grueling and difficult for oil formulations to do well in.
I have NEVER been an "oil additive" guy. I recognize that motor oils are a complex balancing act of additives and messing around with your oil's chemistry can have adverse (mostly long term) effects. So I've always done the tried and true method of using good quality oils, regular change intervals and good filters.
However this technology is quite unique in the industry and is strictly an In Situ DLC coating unlike other solutions based on competing technologies like HBN (or older chemical friction reducers like MOS2 that have quite a few other issues as they break down or absorb water, which can actually become abrasive thus increasing wear and friciton as they break down). Enjoy.
  • Air Filter Testing and Comparrison (dust capacity, filtration and flow).pdf
  • DLC Additives on Cylinder-Piston Ring Rubbing Pairs.pdf
  • Affordable Diamond-like Carbon (DLC) Coatings.pdf
  • Mechanism behind the interaction of TriboTEX and ZDDP.pdf
  • MoDTC and TriboTEX Interaction.pdf
  • molyInfo (Infinium).pdf
  • Operando formation of an ultra-low friction boundary film.pdf
@TheLion70x7 while a lot of what your saying is true, not much of it has to do with tuning though.
To be honest trying to get a 4000lb awd cx9 to move like its a wrx just isn't gonna happen. The transmission needs to get remapped, it needs a bigger turbo and then a tun by a actual tuner. Not a keyboard warrior. And it might feel a little quicker then and not fall apart in a couple years.
The bolt on for these cars just isn't gonna give it the 60hp everyone is looking for. These cars are pretty well engineered.
I've had a few 400+whp cars and I can tell you when it was 400+whp in my 2100lb crx, it felt amazingly fast compared to my 3000lb integra or my 3700lb evo.
Weight is a killer on these rigs. But it doesn't mean there isn't room for improvement on a tune.
Making good progress on our 2.5t JB4 development. Have boost control up and running, almost have fuel control working, and have the major CANbus channels like knock retard and learned knock value up. Now we just need to sort out what to do with timing and to pull it all together! :)
Show 'em how it's done!! 💪 Good stuff @Terry@BMS, appreciate the check in.
My point is at what cost? On a daily driver, especially something you might tour half the country with, any sort of dyno tuning is NOT going to come anywhere near a full data pack calibration method used during real time driving condition, altitude, various fuel octanes, load conditions, humidity, air temp etc.
I'm sorry but a few hours on a dyno is NOT going to make a reliable engine map. It just can't be done. Those are best reserved for non-dailys that only drive under very similar conditions the mapping was done under.
Like I said, go over the Mustang6G forums and see just how many 2.3T Mustangs or even the Focus RS' or on the subaru forums and find WRX's with cracked piston heads or broken rods after 30k+. A surprisingly high number of them end up with new engines vs. the factory tune.
I previously had a 480 HP Mustang GT 5.0 (2nd gen 5.0 that was Ford Performance tuned with a few other bolt on mods, covered under their warranty since I had the FP stuff dealer installed, otherwise I would never have done it). While that was a unique case, I saw the same thing on the forums with the guys using shop tune this and shop tune that. Lots of guys ending up with issues with after market ECU calibrations after you put a little time on them, not many did stock.
And yah, I agree, a 4000lb AWD SUV just is not going to move like a turbo tuner (WRX, STI, Focus RS, Civic Type R) and forget about comparing to modern high compression V8's (Ford 5.0L, Chevy 5th Gen LT1 6.2L, Hemi 6.4L etc.). One thing I hated about the turbo 4 tuner cars is with every one of them...once you hit 3rd gear all fun goes away. They just don't have the torque that the big V8's do that pull hard all though through 5th gear (about 140 mph). Track times tell the same tale, but that's another story. Maybe a built bottom then turbo 4 making 400 to 450 would be comparable, but that's pricey.
But I digress, I really enjoy the torqy 2.5T in my CX-9. It's quick but not fast (I think 0-60 times were in the low 7's). But a broad torque band makes it pull nice, like a pickup truck, so it's enjoyable to drive and doesn't feel like a dog. It's a good balance of every day practicality with sporty feel and a great chassis to match.
Hey all,
I just got my 17 GT AWD last week and I love it. Being the gear head that I am, one of the things I looked at before buying was the availability of tuning options for the car once I get towards the end of my warranty. Right now all I can come up with is Orange Virus Tuning, but it seems there aren't any credible reviews out for their tunes on our motor just yet. Add to it the fact that the tune with the handheld tuner is $800, I'd be hesitant to purchase it. So this begs the question, anyone have any tuning options or have their 2.5T motor tuned? Alot of the Ecoboost guys are running tunes on their 3.5s and 2.7s and what not and they're showing good power gains with solid reliability, so I'm wondering if the same options exist for Mazda. Any thoughts are appreciated.
Mike
Hey, not sure if you've found anything yet. I just tuned my CX9 and wanted to see if anyone had done it before (I can't see any evidence of it). The CX9 is not something I would normally tune but I'm in lockdown in NZ and got bored (the tune is very mild as I'm separated from the dyno. Would there be a market for this? I'm currently working with Alientech on a protocol so that end users can flash their cars using Powergate 3 handheld.
@sm1ke is on the list of people who ordered I believe. I’ll probably get one once we are comfortably moved in to the new house and have caught up on my backlog of projects.
More options are almost always better! So far the only tuner that's been able to actually offer something for purchase has been Burger Tuning with their JB4 (linked by @MGMGT16 above), which is currently in beta testing.
I did order the JB4, but cancelled my order to put that money towards wheel repair. I may end up with one next summer though.
What platforms have you tuned before? This may be worth it's own thread, if you have any interest in pursuing it further.
Hey, I'm just an enthusiast with access to a lot of expensive tuning platforms (my brother has a tuning shop). I used a master tool (Kess v2) to write the modified file to my ECU but I am working with Alientech to get a protocol for Powergate 3 which is an end-user tool. Once this is available there will be a lot of tuners able to tune this car. I don't think I want to tune anyone's car unless they are in NZ (then I can provide appropriate support). As mentioned though, lots of tuners use the Powergate to provide remote tuning service for their clients.
I've tuned my Mercedes AMG E55 running flex-fuel, a few diesels, and now the CX9. If anyone is interested, the approach I took with the CX9 was to look for the "headroom" left by Mazda engineers, they have tuned the engine well past what we get in our cars, all I did was look for it and allow the car to access more of it.
Was able to get a 2019 CX9 in the office today to test out the new JB4 V1 Application MAF control. Worked like a charm! Testing was done on 91 octane fuel. I used "rigged" connectors for this dyno testing but we're hoping to have the real connectors here in a few weeks and then will start mailing those out to V1 Application customers. CX, Mazda6, etc.
Was waiting to see if you guys were able to Dyno a CX-9 before purchasing. Website says 2017+ CX. I’m assuming that the 2016 CX-9 should be included in there unless you know of a change from 2016 to 2017 that makes it not possible?
As long as it's the same engine. Maybe the website guys just got the year wrong. I'm not sure when the CX9 was first made personally.
Latest posts
