Drive Belt tensioner leaking at 40,700 miles per dealer
How about mine? 112,000 miles on this one, unless it was changed before we bought the car around 52,000 miles. Same with the serpentine belt.
It leaked than dried. :unsure:
At 112,000 miles, you may consider to change the serpentine belt and water pump belt along with belt tensioner. Then at 120,000 miles, the engine coolant needs to get changed.
I highly recommend changing the water pump at the same time if financially possible at that mileage. If not then no big deal.
One more vote to change water pump along since most of the work is already done for disassembly of the belt and tensioner but it will cost you some coolant as well. Its easy work though if belts are removed already.
View attachment 233139 that's how leak is looking. I'll check the other thread mentioned above.
I got my replacement part from an online store. Though the online site and order lists it as PE03-15-980C, what I received was PE02-15-980 but with the correct serial number: F569897.13
It is INA brand and made in Slovakia.
Also, as many of us faced this issue around 29K miles, I suspect that many cars have these leaking early on and only caught in 30k service where these are inspected as per the service manual.
Yep the part number of this OEM belt tensioner is really confusing. And you received left-over stock PET2-15-980 as I did go to my Mazda dealer and checked the actual situation in Mazda’s parts system. The PET2-15-980 has been superseded by PE03-15-980C months ago, and PE03-15-980C tensioner is the one they’re getting currently from Mazda. But when I compared 2 belt tensioners side-by-side physically, strangely the serial number on newer PE03-15-980C tensioner has older number F-569897.10!
Belt Tensioner - Shouldn't this be a warranty item?
New Threads
