 - Plano, Texas, USA
Wow I envy you having a $1,200+ QuickJack to use at home! My wife definitely wouldn’t let me invest that kind of money for the QuickJack even if I want to!This weekend I put the new GT-R up on the QuickJack to make mud flap installation easier. Get those big wheels out of the way. The wooden blocks just give me an extra few inches of lift, don't really need them.
Also poked around a bit underneath. Took the fill plug off the rear diff, and it looks like the fluid is low as I read to expect. Just hard to tell by how much. I was planning to also check the ATF level, but didn't really have time to remove both engine underbody trays to get to the dip stick. Maybe in the spring.
Yep another testimony that the rear differential lubricant is low from factory. You would need additional 0.3~0.4 quart of SG1 to fill the rear differential up to the fill hole as stated in Mazda Factory Workshop Manual. And don’t be surprised if you find out the ATF level is low from factory when you have a chance to check!
