Digbicks1234
16.5 CX-5 Touring/2023 CX-9 Touring
Hi All,
I was wondering if anyone has tried out the Ruthenium plugs on Rock Auto? It's supposedly better than iridium and platinum. If anyone has them installed, would you mind comparing them to OEM?
https://www.rockauto.com/en/moreinfo.php?pk=9779940&cc=3312788&jsn=1290&jsn=1290&jsn=1290
Ruthenium HX
NGK Spark Plugs is introducing the latest technology in high ignitability spark plugs to the automotive aftermarket: NGK Ruthenium HX. Today's efficient engine designs create more power while using less fuel and this has shortened the life of traditional Iridium and Platinum spark plugs. In response, NGK's patented Ruthenium technology is used for maximum durability and performance in newer engines where efficiency is demanded.
Features & Benefits:
- DFE (double fine electrode) and PSPE (projected square platinum electrode) tip designs. DFE maximizes ignitability while reducing emissions for low heat engines, and PSPE provides the best ignitability and service life for high heat (typically turbo and supercharged) engines.
- Superior oxidation resistance and enhanced blistering/anti-peeling to provide the most optimal durability at high temperatures in various driving conditions.
- Advanced high-ignitability technology that provides more complete fuel burn than other precious metal spark plugs, resulting in quicker throttle response, smoother idle, and better cold starts.
