- Central Virginia
- 2019 CX-5 Reserve
Another member commented that he liked his Automatic Climate Control system because it does not start blowing air until his car warms up. Mine has never worked that way.
I've had the car for about a year now, and the fan is nearly full-blast (one or two segments below 100%) the moment I start the car...this is in Auto mode.
Most recent incident: I had not driven my car for a couple of days (there was no residual warmth.) I got in last night about 9PM (several hours after sundown), started it up, and the fan immediately blasted ice-cold air. The outside air temp was 35°. The System Temperature Setting was 68°. Driver & Passenger temps are Synched. One the cabin temperature reached 68°, the fan automatically kicked back to a low setting.
The system seems to be operating as described in the manual (which is silent on this issue.)
-The Power light is lit
-The Outside Air Intake is lit
-The AUTO indicator in the driver side control is lit
-The SYNC indicator in the passenger side control is lit
-No other lights are lit (including A/C)
Of course, in the summer, the A/C is immediately available and the fan should start blasting right away.
It's worked this way since I got the car.
Is this normal? Shouldn't the fan be off until the car warms up, then heat the car, then kick back when the cabin is at temp?
