As the titles states, has anyone been able to figure this out? I have recently leased a 2020 CX-9 GT, and so that's been my biggest annoyance so far.
Pop it into Reverse, engage the emergency brake (just in case), then press the Settings button (gear icon) on the display. You can change the default display mode here (as well as display settings such as contrast and brightness).
Thanks for the tip. Never bothered trying because I would just quickly hit the infotainment wheel. Car's out of town with Mrs. Will try to program this upon her return
I believe the process I gave only works for the 2019 models (or the firmware that comes on 2019 models). Based on Toronto-CX9's account, it seems that they changed it in 2020. The view settings may be switched by pressing the command dial, but I'm not sure if that will permanently change the default. After a quick look at the 2020 manual, I wasn't able to find the option for changing the default view.
Same here, no option to change default view.shoot i have a 2019model with firmware 70.0.335 and it doesn't have this option, i can only update the color and brightness settings =(
you and be both.That's a strange decision by Mazda to remove this option. Sigh, I guess I will have to keep pressing the scroll wheel every time.
