Maintenance Procedures, Milage?
Pitter
2020 CX-5 Signature Azul Metalico
Contributor
What are the major maintenance operations apart from oil change and checking this and that, and at what milage?
Brake fluid must be changed every 2-3 years
apparently that is not in (some) Mazda literature
Tires must be replaced after 6 years past the date code on the sidewall NO MATTER HOW MUCH TREAD IS ON THEM
* these are both very important safety issues
How can you visually tell when the Brake Fluid needs to be changed? My 17' has 20k miles. I thinking pretty soon then? I do all of my service at Mazda if that helps.
Visual test would just be for the brake fluid level in the reservoir. You need to get a little meter that can read moisture content in the brake fluid. 2% or more moisture, replace it. Usually replacing every couple of years should be sufficient.
So, it's probably about time on my 2017 GT, eh?
My Mac computer is screwed up and I have to use an on screen keyboard which I forget to use sometimes.
