Anyone thats changed or upgraded their exhaust and/or muffler tips on a 17-19 cx5, could you please post pics and details? Havent decided which way to go...3.5 or 4 tips and whether or not to go straight or with a slight turndown
Ha, not looking to go that big. But stock looks like dual pea-shooters. An extra 0.5-1* outer diameter on tips will still be plenty far from touching the bumper.
Stock. They look fine. There is a reason for the gap. One I amusingly learned when a highschool friend years ago melted the body kit on his civic.
At best it is a 250hp pea shooter. It fits with the narrow tires and output.
Yeah true, and I believe it would*ve looked better with a single muffler/dual pipes sitting on one side instead of a faux dual exhaust for an NA 4-cylinder. Guess it*s the unnecessarily large bumper cutouts that give it the pea-shooter look.
I'm thinking of getting a 3" clamp on tailpipe extension something like this https://www.amazon.com/dp/ (commissions earned) to slide over the OEM tips. Just for temporary use when I am using my trailer-hitch mounted cargo basket. The basket corners (plastic) are right behind the exhaust outlet. Without something like that, I don't think it will survive hours of highway driving.
Those probably won't fit over the OE exhaust finisher tips. Those are made for welding onto bare pipe.
"unnecessarily"...how do you know? Why are they like that? Ponder it for a bit. There may be more engineering that went into it than you're giving credit for.
Further, I'm fine with the exhaust. It's a helluva lot better than the flattened Y-pipe on my LT1 and LS1 cars!
Also consider that exhaust systems are more complex than I think you give them credit for:
https://motordyneengineering.com/exhaust-backpressure-and-scavenging/
One of the first things I did was changed out the tips, I got 3.5" tips welded on.
That looks perfect! Got a rear shot?
Whatever you do, don't buy these: https://www.amazon.com/dp/ (commissions earned). Crappy workmanship, and they started to show rust spots 2 weeks after I installed them. Fortunately, I was able to get a refund.
Took this with my phone, zoomed in a bit.
