and does it matter which orientation you put the bulbs in? thanks for the heads up!
Yes, all LEDs are polarized. You have to try it out for each installation, or you can read the color-coded wires feeding to bulb holder if you can see the wires. Many suggest you need to remove the fuse or negative post, but it would be a hassle to test the polarization of the LEDs.
ahhh, gotcha. thanks yrw!
thats what I was unsure banjos, thanks for chiming in!
Halfway down the product listing for those Amazon LEDs, under Product Description, there's a section titled Note.
3.If the LED does not light up, simply flip it 180 degrees (reverse the polarity),if the bulbs has a flicker,please contact us to solve your problem.
yup!
Sorry but I don't believe you. The only reason the seller put it like that is to cover his ass if your car has some kind of unique setup that does require them a certain way.
There is no way on god's green earth that I successfully installed a full set of interior LED's (and license plate) that I bought on Amazon and got every single one right the first time. Since I hated those I then emoved those and put the Super Bright LED's in... again correct every time. Impossible.
Funny how you search for POLARIZED INTERIOR LED BULBS and the first 3 hits are: Amazon. 4th hit ledunderbody.com -minus the word Polarized.
Next: Advanced Auto Parts also minus the word polarized.
I am emailing SuperBright and will report back. I will also reverse a bulb in my car (which I don't have access to right now or I'd be in the parking lot lol) and see what happens. The research that I quickly did do shows LED bulbs can be either or.
And let's face it most Amazon sellers are juat reselling stuff they've bought in bulk, they aren't the actually makers.
I cannot believe I successfully replaced every bulb correctly the first time. This is where my disbelief comes from.
LED = Light Emitting Diode
A diode has a polarity. It will only allow current flow one direction. You can install it backwards and not be concerned with damaging the circuit, but it will not illuminate. End of story.
I am intimately familiar with what a DIODE is. I can even draw one in a schematic without Googling it. Part of my Electronic Engineering education.
LED's have been around since the 60's.
The first POLARIZED LED WAS DEVELOPED IN 2008!!!
"In recent years, light emitting diodes (LEDs) have begun to change the way we see the world. Now, a Rensselaer Polytechnic Institute student has developed a new type of LED that could allow for their widespread use as light sources for liquid crystal displays (LCDs) on everything from televisions and computers to cell phones and cameras.
Martin Schubert, a doctoral student in electrical, computer, and systems engineering, has developed the first polarized LED, an innovation that could vastly improve LCD screens, conserve energy, and usher in the next generation of ultra-efficient LEDs. Schubert*s innovation has earned him the $30,000 Lemelson-Rensselaer Student Prize."
I promise you the $10 Amazon LED's are not 'ultra efficient'.
I'm curious as to what Superbrite has to say. Funny, I thought about sending them an email based on what I read yesterday.
When I did a quick search on this yesterday, I found electronics forums with comments from 2015 stating that all LEDs are polarized. After all, they have a DC circuit. We all know that things won't work if the batteries are installed backwards (except maybe regular filament flashlights).
Another forum I found referenced someone buying a non-polarized LED that used bridge rectifier circuitry off of EBay...this was a 2007 discussion on a non-automotive bulb.
I also saw something on Superbrite's website about observing polarity, but lost the thread on those search results and could not navigate to the source page...and Superbrite has a wide array of commercial products, so I was not certain what that specific reference was to.
I took electronics a long time ago, but that class included tubes as well as transistors (ask me about suppressor grids).
'Ultra efficient' LEDs has nothing to do with the nature of polarization on LEDs. If your theory is correct, we can easily reverse our battery posts and everything would still be working!
And just because "polarized LED" has a word "polarized", doesn't mean it can be used in reverse polarization from its DC power supply. See the definition of this "polarized LED":
Schuberts polarized LED advances current LED technology in its ability to better control the direction and polarization of the light being emitted. With better control over the light, less energy is wasted producing scattered light, allowing more light to reach its desired location.
And i can confirm they ARE polarized. At least for the ones i got. One way i tested before putting them on is to turn the light on and touch the connection with the bulb. If it doesn*t light up just flip it amd install it.
I'm also an EE, but RF focused. I'm looking forward to your explanation of how an LED can function independent of polarity. I'll admit, my LED experience is limited to my education from 30 years ago.
That was part of the confusion on forums when folks asked the question.
"Polarized" refers to light waves, like the polarized lenses on sunglasses (and as the quote you provided).
"Polarity" means observing + and -
But there are LEDs whose circuitry makes them polarity-neutral, meaning they work regardless of which side gets negative and which side gets positive.
I found this in the FAQs of truck-lite.com
"<i>By nature, LED lights are polarity-sensitive. If the voltage is of the wrong polarity, it is said to be reverse-biased. Very little current will flow, and the device will not light up. <B>Truck-Lite has developed LED lights that are not polarity-sensitive.</B> This is normally indicated in the features and benefits of such a product, but we recommend contacting Technical Support if you have questions on a specific product.</i>"
I want to hear what Superbrite has to say about their product. As I stated, I nearly sent them an email myself yesterday as I was reading on this issue.
Inquiring minds want to know.
Interesting conversation. I found this on the web fwiw:
There exist packaged LEDs with two die connected in parallel but with opposite polarity with respect to the two input leads so that light will be emitted regardless of the polarity of the applied voltage.
The example that first comes to mind are the bi-color LEDs(or tri-color), such as the ones with red and green die. By control of the direction of the applied current it can be made to shine red light or green light. When subject to AC it appears (Red + Green) = Yellow.
source: https://forum.allaboutcircuits.com/...rized-and-non-polarized-led-different.140016/ [post #4]
That's followed by a little schematic. If that's correct, and it sounds correct, the packaging makes all the difference, and could be designed to supply the same color light regardless of polarity. We all agree that diodes only pass current in one direction. But we're talking about "bulbs" which are more than just diodes.
And don't let the question of the polarity of the light produced confuse the issue!
Another interesting sidenote. 7 referred to his "electronic engineering" education. When I was in school, it was called "electrical engineering", long before ICs, etc. Remember "solid state"? :)
