MSP part out
I'd like to sell as a whole but will part out if necessary. Engine had the rod thrown threw the block and after 2 engine rebuids over the past 3 years I'm giving up. Clutch, water pump, oil pump, all belts, maf, coil packs and 8mm wires, turbo, pistons (if they're still good) have less than 7,000 miles on them. Engine rebuild was supposed to be forged but after looking at receipts it looks like they only put forged pistons. The car has a front mount intercooler with hard pipes and a greddy type rs vta bov. Exterior is probably a 6 out of 10 and interior is 9 out 10. Looking to get $2,000 as is.
Interested in the stock shifter knob if you have it and the VICS solenoid on the intake manifold.
I'm interested in several items. I think some of them are gone. You still have the front lower chassis tie brace?
I do still have that. Let me know what else you need
Interested in exhaust manifold if you still have it. Driver's side axle (maybe both), possibly the struts if the deal was good enough. Radio pocket with door. Definitely need the FM antenna end from it. About 3 to 6 inches of the antenna radio wire including the end. Still thinking of stuff. Side mounting brackets for rear subwoofer enclosure. Would also need the bolts for the chassis tie brace I asked about first.
I should have everything except maybe the subwoofer mount bracket. I sold the enclosure some time ago but I don't remember if the brackets went with it. As far as the struts, I'd like to have yours in exchange plus some $$ so my car will still be maneuverable. If you PM me your number I'll take pics tonight or tomorrow so you can see the condition of the items.
Okay, modifying this a little bit. Struts are off the list. Got mine from my old MSP installed and they turned out to be still be very good. I won't need the antenna end either. Long story, but what was cut on my car was the XM radio antenna. What kind of price are you looking for on the exhaust manifold and the axle (or both axles)? Also, do you have the remote entry key fob and how much for it? Thanks.
pm'd
