GJ, when are you going to put Redline in YOUR Mazda's Skyactiv?
That said, I've used Redline. It was nothing special and the transmission was temperamental afterwards. Just another reason I don't dick with changing transmission fluid anymore. Manual, or auto.
*In rainy weather, I would have to double-clutch to get it into 1st gear when I cranked it up in the morning, and it would grind on 2nd gear sometimes on the first shift. 370Z with about 1500 miles on it when the MT-85 went in, so no, it wasn't done "late in life". Symptoms remained for the entire 34K miles I owned it. Yes, rainy weather made it a PITA to get into 1st gear off a cold start unless I double-clutched it. I used MT-85, which was specifically formulated for the transmissions in G37/370Z vehicles, per Redline.
My other experience with manuals was my WS.6 Trans Am, at 76k miles we swapped the transmission fluid. I went with Mobil 1 full synthetic that met the spec for that transmission (T56). In a few thousand miles, it became very notchy. I went back to the GM dealership, bought the GM fluid, and swapped it in, and in another few thousand miles it was 95% back to how it started...never was as slick as before I messed with it though.
As to automatics, the list is even longer of failed and quirky transmissions when I had fluid replaced by the dealer between 68 and 110k miles.
Benicia, Calif. (September 1, 2010) – New from Red Line Oil is MT-85, the latest in a full-synthetic family of products for manual transmissions and transaxles. This 75W85 GL-4 gear oil is designed to fill the viscosity gap between MTL (70W80 GL-4) and MT-90 (75W90 GL-4), making it a perfect fit for many Nissan, Mitsubishi, Hyundai, Kia and NV4500 pickup truck transmission applications.
https://www.z1motorsports.com/transmission-driveline/red-line-oils/red-line-mt-85-p-4770.html
Recommended for Nissan 350Z and 370Z (also most Maxima, Altima & Sentra),
Safe for brass synchros, as it lacks the reactive sulfurs found in most GL-5 oils that cause damage
Offers quicker shifts, perfect synchronizer coefficient of friction
Eliminates notchy shifting, even when cold
High performance gear protection and longer synchro life
Recommended for GL-1, GL-3 and GL-4 applications, as well as where most special synchromesh fluids are specified
Satisifies the gear oil viscosity requirements of 75W, 80W, 85W and motor oil viscosities of SAE 30 and 5W30
Ya know, I came to the conclusion years ago...the company that actually designed the vehicle....MIGHT just know what the hell they are doing more often than the aftermarket, or you, who read "something on the internet and are now an expert". I learned this by being "that internet expert" until I'd burned enough thousands of dollars of my money (2 replaced automatics, 2 quirky manuals, and another quirky automatic....all of which functioned JUST FINE until I had the fluid dicked with) to finally sit down and say "Damn...I was wrong. That hurts."
I also love some of your explanations of "Mazda is just trying to break your car so you will have to burn more money". Yeah...because every auto manufacturer loves tanked CR ratings, higher Edmunds True Cost to Own costs, and forums full of "their junk broke and my *insert brand* got twice the miles..."
