- 2024 CX5 Akera G25
Mazda here in Aus typically replaces any CX5 factory fitted Panasonic batteries that fail within 2 years under warranty. And some extend that a few months beyond 2 years. Replacements also come with a 2 year Panasonic warranty.
Just curious as I'm just about to replace my battery.......If I DON'T do the above reset will that mean the annoying istop will be permantly switched off?![]()
Agreed....... about to take the car in for it’s first 1,000 klm free service and will be asking the service department if they can deactivate it.
replaced it with optima yellow top.
you could use ordinary maintenance free or even low maintenance automotive battery but from what i've read it would not survive that long because of the killer start/ stop feature.
the EFB battery that came with the car didn't last 2 years. trying this AGM battery see how it would last
Heya, Just a question and sharing of my experience with i-stop. I used an "inteligent" type charger and the i-stop, well stopped working. Upon investigation at dealer, it was found system is stuck at 75%, where it was when I hooked up the charger, supposedly. Did the whole reset the other day as per this post, but charged battery till full prior to connecting earth and sensor cables. I-stop works again.
My question is then: Should I disconnect the sensor cable prior to charging the battery to avoid the whole reset procedure?(vehicle in storage for periods 7days or so)
On CX5s and other Mazda's with the i-stop system, i-stop may not activate after the battery has been replaced or was disconnected during some servicing.
In this case you will either need to ask your dealer to reset it, which they can by connecting up to the diagnostic system, or you can do it yourself.
I found some instructions for a MZR 2.0, but it worked very similarly, as below, on my CX5 2.2 diesel.
1. Warm up the engine. Turn everything electrical off that you can - radio, A/C etc so there is no/minimal electrical load.
2. Switch the ignition off.
3. Switch ignition to on but dont start engine. Long-press the i-stop OFF switch for 3 s within 5 s after switching the ignition ON.
4. Start the engine.
5. Press the i-stop OFF switch. Verify that the i-stop indicator light (green) flashes and stays flashing. If it does not flash, go back to Step 3.
6. Allow the engine to idle for 10 minutes, or until the i-stop indicator light (green) turns off. Mine didnt stop flashing so after 10 minutes or so i just went to step 7.
7. Switch the engine off. Wait a minute or two.
8. Start the engine. Go for a drive, and check that the i-stop system operates normally. Those with i-stop will know that you may need to drive a mile or two until it activates. Remember that i-stop will not operate when (a) diesel engines are in regen mode, and (b) in some other conditions - see your manual for details. Also, if a new battery was fitted, it may take some time for the new battery to fully charge up before i-stop will start working. Go for a decent drive so it gets fully charged.
9. If i-stop operates as normal, you have successfully reset it.
Cheers!
Cheers!
Cheers!
Honda’s Auto Idle Stop system used on Pilot 3.5L V6 did gain 1 mpg on EPA ratings when it started to feature Idle Stop.No iStop in US models. We got cylinder deactivation on non-turbo engine. (2 out of 4 while cruising on light throttle).
The reason offered by Mazda for non-having iStop was that, US EPA test process disfavors iStop since it does not show MPG improvement. I maybe wrong here, but idling is not part of the test.
step 4 didn't happen (it was already on)... yet this did the trick.Note: Only Mazda Models with i-stop are applicable.
1.Turn on the ignition and do not start the vehicle.
2. Press the brake pedal an accelerator pedal simultaneously (de break pedal remains pressed)
3. Engage the gear lever in N.
4. The triangle warning lamp appears on the instrument penal.
5. Press the accelerator pedal for three times continuously.
6. i-stop will be green and flash for five times.
7. Engage the gear lever in P.
8. Turn off the key and turn it on again, and the reset is completed
I hear somewhat a version of procedure 2 before... but it never worked.1. Find the engine hood, find the fuse box and pull the ENG+B (7.5A) out. And then, unplug the smart battery sensor plug of the negative pole of the battery.
2. Unplug the ENG+B fuse and the smart battery sensor on the negative pole of the battery. Power off for over 5 min. Plug the ENG+B fuse and smart battery sensor plug after 5 min.
3. Turn on the ignition, do not start the vehicle and wait for 15s.
4. Long press the i-stop and do not press it until the i-stop lamp in the instrument penal turns from yellow to green and flashes, turn off the ignition.
5. Close the engine hood and start the vehicle. Turn the steering wheel to the most leftand then the most right. And then return the steering wheel to the middle position until the engine is stalled.
6. Turn on the switch to the ON P[osition, press the i-stop button for 5s, and then release and start after more than 3s. At this time, the i-stop lamp is green and flashes twice. Stall the engine and confirm that matching is completed after engine start.
