calebian21
- 2015 Subaru WRX
Anonymous MD, I'll try and grab some tonight for you!
Looks very good calebian21!! Well done on a fantastic installation.
If I may ask: Did you connect it to the High Beam Relay? Have you installed a seperate switch inside the vehicle? I am also thinking of using a wireless 12v remote switch because I do not want to make holes in the dash....but if it can be switched with the High Beam Relay, that would suit the installation much better.
That'd be awesome if you can just detail what part you bought and how you installed it.![]()
Anyone try mounting a lightbar on the 2017+ models? Was thinking about a 20"-24"/2 row bar in the space on the bottom of the bumper, similar to in these pics, but I see nowhere to mount the thing to at a glance without removing the bumper for a closer look. Is the frame of the new model the same as the outgoing, or is it dramatically different?
I question the effectiveness of these light bars vs stand alone single focused light beams, either a fog pattern or driving pattern. I have seen the light bars mounted on top of pick up trucks with lift kits and big tires...the lights are extremely bright, but the light is unfocused. So it IMO is just a blob of bright light with no projection or focus. What does that get you in useful light?
Then again OP placed the lights low towards the ground. That should probably make a difference in keeping the light pattern fixated a bit.
Each individual LED is set within a reflector housing similar to a Halogen headlight on the bar I was thinking about buying. So each individual LED is focused at either 30 deg or 60 deg beam pattern depending on where it is located in the bar, and the actual bar is curved to about a 30 deg beam pattern.
I have a light bar on my quad, and trust me, it is a night and day difference between the headlights on that machine and the light bar in conjunction with the headlights. I've also been in rigs (pickups, jeeps, etc.) with light bars mounted mid - low frame, and the light they project is actually pretty impressive. It isn't really something you'd ever use in a city, so if you're a city slicker, just stick with the headlights. But when you're on back roads in the country, or making long unlit highway drives (aka: not living in the city), it really helps throw light out into the trees and up-road to illuminate moose and other big animals (deer, bears, etc etc.).
Pretty much everywhere except Metro St. John's in Newfoundland is like the latter. Long stretches of unlit highways and twisty backroads. Even the provincial highways are littered with potholes, twists and turns, and large animals. The more light the better. It's a beautiful place, but there's a lot of wildlife on the highways, namely moose, which are 1 : 5 moose per person living on the island (~110,000:~540,000), hahaha. Since I'm moving about an hour outside the city limits in the next year or so, I figure it'd be good to have the light bar for some extra light.
