Thank you for the info. Btw, what brand is it? any links? Again, Thank You! & Happy New Year!
it’s a no brand set from amazon, that appears to be a good quality!
4pieces 30mm hub centric wheel spacers | 5x114.3 5x4.5"| 1.18" inch thick https://www.amazon.com (commissions earned)
Looks good, notice any difference in the way it drives?
Nice! I'll have to give these a try. Easy install?
Yes, it is a pretty straight forward install. One VERY important moment: new spacers must be re-torqued after about 50-75 mi of driving!
This is a good video about spacers installation:
https://youtu.be/JPsaiLiNaLo
You are the KIND of person when asked for help you go all the way. Thanks & GOD Bless... All info are noted..
vitpk1, did you have to do an alignment or camber/toe correction after the spacers were installed?
Hi there, just wondering if you could post a couple of pics at fender height straight down the line showing if there is any poke from the tire? Considering trying this.... Thanks, Foxy
Hm. So the front wheel hubs sit 5mm out more than the rears?
