I am curious about your tire rotations, and your schedule.
How do you rotate your tires?
Rotate every Oil change?
Rotate on a separate milage schedule?
Rotate as needed by treadwear?
Never Rotate?
Same here ( at least Im trying to ⋯Rotate tires on every oil change, which is every 5,000 miles.
For what it's worth, my dealer recommended rotating with every oil change: "more often because of Mazda's aggressive suspension geometry".
There's nothing remotely "aggressive" about suspension geometry or alignment settings on the CX-5. However, that said, If you're changing your oil every 7500 miles (as many here seen to do) then follow the dealer's advice. I change oil at 5k miles (I put less than 10k on the car each year) and rotate tires between oil changes @7.5k.For what it's worth, my dealer recommended rotating with every oil change: "more often because of Mazda's aggressive suspension geometry".
I rotate them when they begin to get loud. No calendar, I just listen to them. I don't drive a CX-5 though.
My tires are BFG KDW2s.
not all tires will get louder as they wear out...
