How long does it take you to do all that zoomzoom1016 (scratch)
For his exterior it took me 7 hours. Washed. Clay barred. Correcting polish. Sealant. No finish polish or a coating. Tack on another 3 hours for those 2 things. Polishing takes a ton of time when done correctly.
But I did spend 2 hours in the beginning on his interior.
Just detailed my buddy's 3 hatchback this past weekend. Modern cars' engine bays are engineered to be water resistant to not have such issues as misfiring, throwing codes, etc. I still cover the coil pack and air filter, if necessary. Other than that just lightly mist the hood underside and bay with water, spray a liberal amount of all-purpose cleaner, use a few different size brushes, mist with water again and turn on the engine to dry. Compressed air helps to get into the crevices.
*But never, ever clean a hot engine. It must be cool to the touch.*
Finish it off with a matte dressing. I use Chemical Guys Silk Shine spray. I also removed some swirl marks from his 3 as well.
Anyone know how to remove baked on brake dust from your rims? I used oven degreaser once in the past, but found out it’s not good for the finish of your rims. Is there any sort of rim cleaner or wax I can put onto the rims to prevent more brake dust from baking on? How often should I do this?
You mentioned to never clean a hot engine bay, why is this? I tried it once and found that the heat helped tremendously with drying the engine bay without leaving any marks.
How did you polish and clean the exhaust tips so well?
A couple questions if you don’t mind..
How did you remove the swirl marks from your paint
How did you clean the interior
How often would you recommend clay barring the paint? Is there any point in polishing the paint if it’s already covered in wax? Can I apply a spray polish with a rag, or is it best to polish your paint with paste and a swirl pad thing?
Damn, any of you detailers in my neck of the woods?
Mostly for the cleaners to not dry so fast and spot everything as you're cleaning. Think of it as a rain shower and then the sun immediately coming out and water spot damage is inflicted.
Thank you for your suggestions.
I tried pressure washing the engine bay when the engine was fully warmed up (without using soap or cleaners) and the engine bay dried really well. looked clean afterwards
Just detailed my buddy's 3 hatchback this past weekend. Modern cars' engine bays are engineered to be water resistant to not have such issues as misfiring, throwing codes, etc. I still cover the coil pack and air filter, if necessary. Other than that just lightly mist the hood underside and bay with water, spray a liberal amount of all-purpose cleaner, use a few different size brushes, mist with water again and turn on the engine to dry. Compressed air helps to get into the crevices. But never, ever clean a hot engine. It must be cool to the touch. Finish it off with a matte dressing. I use Chemical Guys Silk Shine spray. I also removed some swirl marks from his 3 as well.
How well does that Ryobi wand work? I've looked at them in the past
The guy who does maintenance in my community - I thought had an OCD cleaning his old Toyota pickup -realized that was his side gig. Every week he gets one or two vehicles - This time it was a grey Tundra with custom wheels on it wow. I bet its north of $200. Inside out - every god damn square inch. Its a miracle that he does not hoist it on a lift and clean the underbody. He literally cleans for hours and hours.
As far as claying baring the car goes, there is no harm in claying the car too often other then wasting time. A good way to tell if the car needs to be clayed is to do the baggie swipe test. Put your hand in a sandwhich bag and run it along the paint, if it feels rough or gritty then it's time to clay bar. the Clay lifts those bonded contaminates off the surface. Another good thing to do is to decontaminate the car with something like IronX. Iron X will dissolve any iron that has bonded to the paint and remove it so your clay doesn't get as dirty and you'll have less chances of inducing scratches and swirls.
