- CX5
My unit comes with front and parking sensors but it doesn't "beep" whenever I'm backing or parking. I've reached through the web and there seems to be no topic about that.
Here:My unit comes with front and parking sensors but it doesn't "beep" whenever I'm backing or parking. I've reached through the web and there seems to be no topic about that.
More on the front and rear parking sensors. They are activated with a button on the switch panel. This is different from the 2016.5 which had a switch to kill the sensors. They always defaulted to on and had to be switched off.
So, with the switch on, the sensors give off the bleep with increasing intensity as you get nearer an object. An image of the car is super imposed onto the back up screen or any other selected screen when the vehicle moves forward up to about 10mph. In the next photo Im parallel parking back up to another car. You can see the lock in the lines and you can see that the image is showing close proximity at the rear bumper.
As I get closer, the whole thing starts to light up and the front and rear bleepers have distinctly different tones.
These photos show the position of the body coloured sensors.....
A couple of other things. The reversing lights are leds on mine Im please to report. You can see the light from them in the back up camera images above. This shows one of the small clusters.
They are surprisingly bright.....
My SD card for the satnav didnt arrive with the car so Im running without it. In its absence, the nav screen shows quite a nice ships compass. The upper screen is also devoid of those confounded street names that seem to overwrite everything else.
And finally, something a bit different for you US guys and that is this European obligatory rear fog light.
Here:
We also don't get it here... European models have the trajectory on the rear view camera!![]()
We don't get it here either... European models have the trajectory on the rear view camera!![]()
Not even as a dealer fitted accessory (scratch)Lucky you, parking sensors are not available in Canada and I missed them !
We get it here in Asia and the rear fog light
Are those the red lights under the rear bumper beside the exhaust tip?We get it here in Asia and the rear fog light
Yes and usually it's a single bright red light low on the driver side. Anchorman is in UK hence his rear fog light is on the right hand side:Are those the red lights under the rear bumper beside the exhaust tip?We get it here in Asia and the rear fog light
⋯ And finally, something a bit different for you US guys and that is this European obligatory rear fog light.
In US or NA market Mazda does offer a Rear Parking Sensor as a genuine Mazda accessary. But that's a totally different system and not integrated with factory infotainment system and backup camera. It only beeps and has no visual like Anchorman's factory system. There's even an odd and useless on/off switch installed in the trunk!Not even as a dealer fitted accessory (scratch)Lucky you, parking sensors are not available in Canada and I missed them !
