Maybe here had it as well in 2016. May need to check the brochure when I get home (have 2016 & 2017)
Just checked the 2016 brochure and yes EPB came standard across the range.
In Australia, use of the parking brake is a requirement when a vehicle is parked and left unattended on a public road.
"Securing your vehicle
You must secure/lock your vehicle before leaving it parked on a road. Your vehicle is considered unattended when you are more than 3m away from it.
Before you leave the vehicle you must:
switch off the engine
apply the parking brake
remove the ignition key if there is no one 16 years of age or older in the vehicle
wind up the windows if possible—a gap of 5cm or less is acceptable
lock the doors if possible.
This rule applies to all road-related areas, including car parks."
Most people apply the handbrake. You can tell the ones that don't on account of the swinging on a decline for a brief period
