2017 DRL/signal light emulation
mikflores
'17 Mazda6, '17 CX-5
Here is a quick video I took of my CX-5 GT with headlights on and hazards. Since we know the DRLs have the headlights on as well, but slightly dimmer, this should work as a quick reference. I'm concerned with the bright headlights the turn signal light will get lost or unnoticed. What do you think?
https://youtu.be/VeL-NymelI0
Pipemajor is changing his turn signal bulbs to a more brighter ones
Sent from my SM-G935F using Tapatalk
Thanks for the video. It's already worse by moving the turn signals from outboard to inboard of the headlight system, front turn signals on 2017 CX-5 almost feel like "hiding" behind the Signature LED DRLs and LED headlights. They're not very easy to see under any circumstances!
I'd entered the comment on this matter after attending the Mazda CX-5 Ride & Drive Event in Dallas. I'm going to send in the same comment to Customer Experience Center of Mazda North American Operations via email and chat, may even call the rep. If I were a 2017 CX-5 owner, I'd file a complaint about the DRL's configuration with headlights on at NHTSA website. The more people complaining, the easier to let MNAO aware they configured something which is different from everybody else in the world, and affects the safety of driving. Headlights on with DRLs is even illegal in EU countries!
Obviously its not as bad as it seems otherwise the relevant authority in each country would not have allowed this to have passed the requirements.
Agreed. I'm starting to see a few more on the roads around town and as another motorist haven't had any issue seeing the indicators.
Maybe it was the video but the mirror-mounted LED turn signals were difficult to see in the daylight.
Don't give government lackeys too much credit. (kiss)
Exactly. EU has outlawed headlights to be DRLs in 2011. In the mean time our NHTSA still can't make a decision to legalize superior and much safer adaptive-beam matrix LED headlights such as Mazda's ALH since Toyota filed a petition in May, 2013!
No such issue here. VW Golf's have halogen headlights as DRL's. Infact, early CX-5's had the same thing
『Microphones OBT games for kids Playstation games Wii games』 (uhm)
Spam post. Already reported it
Anyways still waiting to see one on the road with DRLs on and using turn signal. Patience is needed. Will take a little while due to approximately 2200 sales a month Australia wide
Sent from my SM-T805Y using Tapatalk
The full-powered LED low-beam headlights as part of DRLs is different from reduced-intensity halogen high-beam DRLs. Low-beam DRLs are unnecessary and affect the longevity of the expensive LED headlights. This also opens up a new can of worms for those anti-DRL advocacy groups. "Thousands of complaints regarding glare from DRLs were lodged with the DOT shortly after DRLs were permitted on cars, and there was also concern that headlamp-based DRLs reduce the conspicuity of motorcycles, and that DRLs based on front turn signals introduce ambiguity into the turn signal system."
"Motorcycle's low beam headlamp has been wired to illuminate whenever the engine is running, either as a matter of law or of voluntary industry practice. Some motorcycling advocacy groups are concerned over the potential for reduced motorcycle conspicuity with the introduction of headlamp-based DRLs on cars and other dual-track vehicles, since it means motorcycles are no longer the only vehicles displaying headlamps during the day." School buses with low-beam headlights on all the time have the same argument.
"Because the power to run the DRLs must be produced by the engine, which in turn requires burning additional fuel, high-power DRL systems increase CO2 emissions sufficiently to affect a country's compliance with the Kyoto protocol on green-house gas emissions. For that reason, low-power solutions are being encouraged and headlamp-based systems are not allowed after DRLs became mandatory in Europe at the beginning of 2011. LEDs and low-power, high-efficacy, long-life light bulbs produce appropriate amounts of light for an effective DRL without significantly increasing fuel consumption or emissions."
Study has showed "compared to any mode of headlamp operation to create the daytime running light, functionally dedicated DRLs maximize the potential benefits in safety performance and minimize fuel consumption, glare, motorcycle masking, and other potential drawbacks."
My biggest safety concern is some 2017 CX-5 owners would forget to manually turn on the headlights in the dark if they don't have Auto-Headlight function or don't use the function even if their CX-5 has it. This had been happened so many times on DRL-equipped GM vehicles using low-beam headlights in 90's. It's so obvious seeing this scenario that a GM car is driving in the dark with the headlights on but no tail lights as the driver didn't aware he's using DRLs driving in the dark!
That will happen regardless of them not having the switch on auto for the simple fact that nowadays the dashboard is always back lit where as in the past, having the dashboard be dark at night was a good hint to turn on the lights
PS no complaints here AFAIK about DRLs
Dang son, you really have it out for these headlights! The reasoning in your post bothers me on so many levels. ***EDIT: directed at yrwei52
FYI - The LED headlamp is NOT at full power in DRL mode. It is at reduced power. Pull up to a wall and play with the lights, you will see the difference in intensity against the wall. And IMO anyone complaining about glare due to a headlight being used as a DRL in the daytime is completely full of rubbish. Then how could they be used at night, when contrast between surrounding areas and the headlights is MUCH higher????
If a headlight can be used at night there is NO reason it can't be used during the day, and that's the bottom line.
Then you argue about longevity of the headlight....
Headlight uses LEDs. Same technology as is in the "signature lighting" strips (in the top model) and individual DRL bulb in the lower model. What's the difference between using an LED in an accent strip vs an LED in a headlight housing with any DRL system needs to be on all the time and neither components are serviceable? None.... If the accent strips are used all the time and one goes out, the housing needs replaced. Same for the headlamp now. It's an unfortunate truth, but it is the price to pay for more advanced lighting.
IMO, this is a ridiculous argument. You're saying school buses are complaining about trying to be safer? LMAO! Where is this coming from? You've gone from arguing that a DRL in a headlamp is bad to arguing that DRLs in general are bad. DRLs have been the law here in Canada since 1989, purely for safety reasons. From the exact same 14 year old report that you linked to are the figures the author used to advocate for the use of DRLs:
According to European studies on the effectiveness of DRLs in improving road safety , the
potential savings are:
• 25% of daytime multi-vehicle fatal accidents (11% of all non-pedestrian fatal accidents)
• 28% of daytime fatal pedestrian accidents (12% of all fatal pedestrian accidents)
• 20% of daytime multi-vehicle injury accidents
• 12% of daytime multi-vehicle property accidents
The headlights in this application are LED...
If this happens it is the driver's fault, NOT the car's! There are other ways to know that headlamps are on or not at night time including, but not limited to: changes in dash illumination (either becomes illuminated, or if it is already illuminated it becomes dimmer), headlamp indicator in gauge cluster if gauges are always illuminated, the fact that whatever light projected forward from the car is not typically sufficient for night driving and the driver should recognize something isn't right.
The OP's original concern is visibility of the turn signal. The only relation to the DRL system at all is the fact that the DRL "signature" lighting illuminates the same area of the light housing at the same time of the turn signal, potentially reducing visibility of the turn signal.
If anything will come from the original concern in this thread it will be that Mazda devises a way to turn off the DRL adjacent the turn signal when the turn signal is turned activated which some other manufacturers already do. I'm not sure if that is a mandatory requirement due to a regulation somewhere or if that is voluntary (my assumption) but for whatever reason Mazda didn't have to do it so they didn't. If they had to do it to satisfy some regulations, it would've been done.
Here's a link explaining what I mean. Ironically this link also says why I believe the headlight itself is a part of the DRL system... because the headlight is the DRL (as it is brighter) and the lighting strips are the "signature lighting" that happen to work along side the DRL.
http://jalopnik.com/heres-why-modern-cars-turn-off-one-of-their-lights-when-1792394567
At least in the US where this article comes from, it appears that Federal Motor Vehicle Safety Standard 108 is what would require the DRL to be deactivated when the turn signal is activated.
Here's a specific requirement from that specification which applies to the CX-5.
Each DRL not optically combined with a turn signal lamp must be located on the vehicle so that the distance from its lighted edge to the optical center of the nearest turn signal lamp is not less than 100 mm...
I'm assuming as I don't have the headlight system output numbers, Mazda was allowed to use to keep the signature lighting strip / DRL illuminated next to the turn signal as one of the following exceptions applies to their design (at least in NA). The signature lighting isn't bright enough to be considered an issue, or the turn signal is bright enough compared to the DRL that it isn't considered an issue, as exemption C does not apply to the new CX-5's design:
(a) The luminous intensity of the DRL is not more than 2,600 cd at any location in the beam and the turn signal lamp meets 2.5 times the base front turn signal photometric requirements
(b) The DRL is optically combined with a lower beam headlamp and the turn signal lamp meets 2.5 times the base front turn signal photometric requirements
(c) The DRL is deactivated when the turn signal or hazard warning signal lamp is activated.
I tend to believe that if you are in the US and you have concerns with the signature lighting / DRL / vs turn signal the above regulation is where you have to start arguing your case.
wow, seems like an oversight on Mazda engineers side, at first when you shot the video from the side angle, I thought the turn signals were bright and distinct enough reflecting off their reflectors,
but as you moved towards the head on view, the yellow turn signals somehow got smaller and smaller due to their deep recess and made worse by the long grill snout sticking way forward almost to point that they look like parking lights rather than dedicated turn signals,
then I thought maybe the side mirror signal lights may compensate and unfortunately even those, Mazda made them so thin and tiny you can barely make them out....
I would complain like yrwei52's suggestion and get them to turn off the headlights with DRL's, makes no sense......
Response from Mazda NA:
Thank you for your email.
There is a helpful chart on page 4-52 of the owner’s manual that will show you the options and the conditions when the headlight will be on.
If as stated in your email the headlights are always on when the vehicle is moving, even if the headlight selector is in the OFF position, then your vehicle is not operating within factory specification in which case we recommend diagnosis by our technicians at an authorized Mazda dealership.
Here is the closest dealership based on your zip code:
Thank you again for your email. If you have any questions in the future, you can reach me directly using the number and extension below.
I have tried to explain to them that the actual headlight is part of the daytime running light setup for some reason, different than both Japan and Australia, but no luck with them understanding so far. Even though DRL's are not required here, I believe we may be forced into this setup because of Canadian requirements. That is the only reason I can think of.
