2016 CX-9 Aftermarket Wheels (Bolt Pattern/Offset)
New to "this" forum. Just got the wife a 2016 CX-9 Signature, really want to change out the rims cause I want it to be different than all the other CX9's. How does the 22's feel handling wise compared to the stock 20's?
Like what I had mentioned here a couple of days ago, I didn't notice a huge difference in ride and comfort. Feels like the 20s it had on during my test drive. But one thing to really consider is the tire size you want to use. If you go low, you'll be compromising the ride comfort as well as where you can drive her or not. 265/40 R22 is what I'm using.
Hi all,
I'm a future CX-9 owner from Taiwan and I'd like to ask a question.
Can 20"x8.5J et28 wheels fit on 2017 CX-9? (with 255/50/20 tires)?
Sorry for my poor English and thanks for your reply in advance.
Hi all,
I just wanted to share quick snaps of my CX9's summer shoes.
The rims are 20" Rotiform Monoblock in black and DDT.
http://www.rotiform.com/spf-cast-1-piece-w-21894.htm
I bought 60mm blank center caps from eBay, painted them flat black. I then found some original Mazda xals removed the emblems and glued them to the caps with JB weld. It's been two weeks and the emblems are holding strong. Rims now look OEM :)
Here's a vid with instructions on how to remove the caps.
https://youtu.be/V4jaMNPzdXc
I'm happy with the overall look, it's just too bad they aren't 22s.
A question for you guys. The lugs in the rims are OEM and they are a tight fit. I'm looking to get some smaller spline lugs, which color should I go for.
Chrome, black, ofr chrome+black, which is a bit pricier for 20 lugs
https://www.amazon.com/dp/ (commissions earned)
Thanks
Sent from my LG-H831 using Tapatalk
Hi all,
Thanks
Very nice looking rims.
Tried to Match the concept design as close as it could be.
And this is my 2016 CX9 Signature with the 22x9 rims.
This is the nicest CX9 I've come across online so far!! Would you happen to have another picture in better lighting conditions? I'm on the fence on if 22" wheels don't have enough tire to still be practical (for an SUV).
17 CX5 Gt had the stock wheels exchanged to all chrome wow what a difference the car is dark blue in color and blah to see now with the chrome it jumps out to see. I would to get a chrome strip at the bottom of the door at rocker panel like the CX 9 has to chrome it up. I purchased the wheels from Detroit wheels . com easy to work with ask for Brian.
Stryker, looks great! Since you've done the numbers....what offset would you go with on the 22x10.5?
Hi Stryker, can you tell me if your Ace Alloy Convex wheel or tire is flush with the fender? I am buying a new set of wheels and trying to determine what offset I should get. Thank you!
